LED fuel guage
Old Jul 9, 2007 | 03:23 PM
streetbobrob's Avatar
streetbobrob
Default LED fuel guage
I know theres been alot of posts for the LED fuel guages, so heres another. I installed my fuel guage about a month ago, pretty simple, andeverything worked fine. Recently the guage will work sometimes and sometimes it won't. I checked all connections 2 or 3 times, everything is tight and correct. Has anybody else had this problem??
Thanks, Streetbobrob
Old Jul 9, 2007 | 03:30 PM
Airborne350G's Avatar
Airborne350G
Default RE: LED fuel guage
I just installed mine. Sure hope I do not begin to have the same problems. Have you looked for broken wires?
Old Jul 9, 2007 | 04:56 PM
streetbobrob
Yep, I even bought a new wiring harness and rewired it just to make sure. Its pissing me off.[:@]
Old Jul 9, 2007 | 07:40 PM
wideglidebob's Avatar
wideglidebob
thats why on electrical always pay the dealer if something happens they fix, some things are worth the few bucks
Old Jul 9, 2007 | 09:00 PM
boogerbooger's Avatar
boogerbooger
Could there be an intermittent ground connection problem? it sounds like it's not the harness due to replacement already. Use the megohm scale to any wires that need to be grounded. Make sure there is a zero ohms reading using the megohm scale of a multimeter. If you are showing any resistance then it is not properly making ground contact.
third_left_eye
Nov 19, 2020 06:41 AM
Jday53
Dyna Parts
May 14, 2012 07:28 PM
Jday53
Softail Parts
May 14, 2012 07:26 PM
Jday53
Touring Parts
May 14, 2012 07:25 PM
wvsuperg
Jan 2, 2007 04:10 PM
