Question with adding security/deleting ignition
Old May 30, 2019 | 10:03 AM
shodown220's Avatar
shodown220
Default Question with adding security/deleting ignition
Well I keep having issues with my 14 FXDL ignition. The bracket broke on the way home from bike week. This makes time #6 I've had an igniton related issue. I was going to swap the bracket but some asshat at the dealer jbwelded ignition and bracket together and a different dealer couldn't get it apart without ruining igniton in the process. To answer your question I have had multiple dealers multiple times replacing ignition components so I can't pin that crummy work on one in particular.
Anyways I'm looking at having to replace my igniton/housing/bracket now to repair. I was talking with the tech at my local dealer and he said if I added harley system to the bike he could program the bcm for the bike to be keyless. Meaning I could do away with my igniton altogether and the run switch would also power on the bike. Does this sound accurate? I figured I had to have an igniton to turn bike power on but he says no he can program the run switch to do that. I just dont want to spend the 350 for the security if I dont have to. Thanks in advance!
Old May 30, 2019 | 10:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Do you mean Ignition Switch?
Old May 30, 2019 | 10:14 AM
shodown220's Avatar
shodown220
Yes the switch, sorry I was a little vague. The actual part you put your key in to unlock and then turn for power to come on.
Old May 30, 2019 | 10:57 AM
Blue Bob's Avatar
Blue Bob
Yes the factory system allows the switch to remain locked then just use FOB and power / start switches
I bought mine on ebay for $200.00...installed myself ( plug and play) then had dealer marry it to the ECM 1/2 hr $45.00 + $10.00 to pickup and deliver to dealer. It literally takes them 5 minutes. Just be sure they program it correctly so your brake lights and turn signals work correctly. As k me how I know!
Old May 30, 2019 | 03:44 PM
shodown220's Avatar
shodown220
Great! Thanks for the input I was hoping I wasnt going to have to add a toggle or something so this is good news. Thanks again
Swamp_thng666
2014-2024 Touring Models
Apr 30, 2019 10:29 AM
theabominablenick
General Topics/Tech Tips
Jun 11, 2014 10:40 AM
TexasJR
Jul 27, 2011 08:13 AM
onephsyco1
Feb 20, 2008 12:57 AM
BiggestDawg
Jul 10, 2006 06:58 PM
