Poly Riser Bushings
Old Jun 17, 2019 | 08:10 AM
wyotana's Avatar
wyotana
I tried tightening them a bit more and I can't go much more without a breaker bar and I don't want to run the risk of stripping the risers out. I had my eye on a set of alloy art bushings that are coincidentally clear anyways, I'm going to try those. If I still have flex I might look into the solid bushings. I thought about going with just another set of drag specialties but after what HD_Matt said, there might be something to the issue of quality with the drag specialties bushings. Then again maybe not, but we'll find out soon enough. New bushings should be here Wednesday, I'll keep you guys posted.
Old Jun 17, 2019 | 08:14 AM
pab3rd's Avatar
pab3rd
I went with aluminum riser bushings and have not had any problems with them Or excess vibration.
Old Jun 17, 2019 | 08:18 AM
pab3rd's Avatar
pab3rd
Riser Bushings Buyers Guide for Harley at RevZilla.com
Old Jun 19, 2019 | 04:58 PM
wyotana's Avatar
wyotana
Quick update, got the new riser bushings installed and that did the trick. Night and day difference over the old bushings. That being said, I don't know if the new bushings (Alloy Art Gooden Tight) are just that much better than the drag specialties, or if it's because after 20k miles the bushings just needed to be replaced. Only time will tell. Thanks again everyone!
Old Jun 19, 2019 | 05:52 PM
BMyers's Avatar
BMyers
I had a set of Drag Specialist poly bushings that were sloppy loose.
jake.mason.2
Milwaukee Eight (M8)
Oct 8, 2018 06:41 PM
thoner7
Apr 30, 2013 07:16 AM
big papa AZ
Apr 14, 2013 04:20 PM
MNrider
May 2, 2009 08:09 PM
CaliDeluxe
Jul 2, 2007 02:54 AM
