Aligning risers
Old May 1, 2009 | 06:44 PM
MNrider's Avatar
MNrider
Default Aligning risers
I installed some 8" risers on my fatbob. They don't look like they are perfectly aligned. The right side seems to lean closer to me than the left side. Any tips to keep these lined up when installing?
Old May 1, 2009 | 10:40 PM
Mr. Lucky's Avatar
Mr. Lucky
Unless they are bent, shouldn't they self-align with the handlebar installed?
Old May 1, 2009 | 10:44 PM
Dizzzy's Avatar
Dizzzy
I normaly tighten the clamp while the riser bolts are loose. Then tighten the riser bolts after the bars/risers are straight.
Old May 1, 2009 | 11:14 PM
Rick1972's Avatar
Rick1972
+1 on that.... I had the same issue with my SG. Since you have a good idea where the bars will sit in the risers, loosen the clamp and the riser bolts. Once the riser bolts are loose, tighten the clamp to ensure the handlebar is seated in the risers correctly. Then just re-tighten the riser bolts.
Old May 2, 2009 | 12:23 AM
MNrider's Avatar
MNrider
Thanks, i'll give that a try.
Old May 2, 2009 | 08:09 PM
MNrider's Avatar
MNrider
Doing the clamps first then the risers and banging on the bars as I went along did the trick. Thanks everyone.
Mchad
Mar 4, 2020 11:00 AM
jake.mason.2
Milwaukee Eight (M8)
Oct 8, 2018 06:41 PM
grantb
Ironhead
Sep 7, 2012 07:30 PM
high iron
May 23, 2008 08:15 PM
OneBlackFly
Nov 2, 2007 11:42 AM
