Dyna Wide Glide Windshield
Old Jul 18, 2019 | 02:38 PM
  #31
ABQ-Jammer's Avatar
ABQ-Jammer
Originally Posted by sharkey
Wife and I both run the HD QD mounted windshields. Cleanest, easiest to get parts if needed and fits well. When it's off, there's nothing left on the bike. Her's is stock; I installed a couple of Vetter Snap Vents just above the horizontal bar and she claims buffeting is much reduced. Makes sense; if you create a low pressure area behind the windshield, there will be turbulence when air tries to flow into that area. The vents allow air in thru the openings...would probably be nice on hot days, too.
I just replaced my re-curve with a Memphis Shades; will be installing the snap vents soon. It's a relatively tedious and very fussy job. I'll get a picture of her windshield later...
Would love to see the process of cutting and installing those vents. Might be something I'd like to try, since I'm in the desert. What are you doing with your recurve? I've always heard that the re-curves help with the wind on your head.
Old Jul 18, 2019 | 02:42 PM
  #32
ABQ-Jammer's Avatar
ABQ-Jammer
Originally Posted by cvaria
It clamps to stock 49mm wide trees. I think that was standard from 2006 til hd kill dynad off for the new softails.
Thanks for the info. I wasn't sure, and I knew that some of the earlier/other models had 39mm or 41mm forks, plus I didn't want to assume (you know what they say about when you assume...).
Old Jul 18, 2019 | 03:54 PM
  #33
Prodigal_Sun's Avatar
Prodigal_Sun
Mine is a 2003 with the 41mm forks, they changed it 2006, I believe.
Old Jul 19, 2019 | 01:00 PM
  #34
sharkey's Avatar
sharkey
The used re-curve is gonna hang from the rafters; lotsa travel stickers on it...many memories. I don't think the re-curve is necessarily the only answer; I actually believe there's more turbulence but higher up above your helmet...hopefully. I'll document the vent install and do a separate thread in the Dyna section.
Old Jul 19, 2019 | 04:03 PM
  #35
ABQ-Jammer's Avatar
ABQ-Jammer
Alright. I'd need for 49mm forks. Thanks, anyway, unless you want to give me a great price, so I can get new fork clamps that fit mine...
Old Jul 19, 2019 | 04:05 PM
  #36
ABQ-Jammer's Avatar
ABQ-Jammer
Understood about the re-curve, keeping for memories.
Looking forward to seeing the vent install process thread. Thanks.
Old Jul 21, 2019 | 10:50 AM
  #37
NVNobody's Avatar
NVNobody
Im interested in this as well
B.K.
Softail Parts
Apr 2, 2018 08:22 PM
nsnorgrass
Dyna Parts
Mar 6, 2015 03:36 PM
drstephennix
Mar 11, 2009 12:43 PM
freebyrd
May 6, 2007 06:10 PM
WdGldDave
Sep 25, 2006 07:22 PM
