Clutch Adjustment
Old Jun 19, 2019 | 08:21 PM
cycle_man's Avatar
cycle_man
Default Clutch Adjustment
2006 Dyna Wide Glide. I have followed the recommendations in the service manual to adjust the clutch. No matter which I try the 1/2 turn free play or the full turn free play I end up with a clutch that engages the minute I let it out. It also seem to slip at a stop and is almost impossible to get into neutral at a stop. Just bought this bike last year with less than 5000 miles on it. Had the problem since day one. I keep trying different adjustments with no difference. I want a lever that lets out almost agt the very end of travel all my other bikes do..
Old Jun 19, 2019 | 09:09 PM
Qdog002's Avatar
Qdog002
Bike must be cold before adjusting. Are you doing this?
Old Jun 19, 2019 | 09:21 PM
cycle_man's Avatar
cycle_man
Yes bike is cold I adjust it and then try it. Then wait till the next day to try to adjust it again
Old Jun 19, 2019 | 11:41 PM
crusader1xxx's Avatar
crusader1xxx
Are you following the FSM.? Start in the primary and then the cable...
Old Jun 20, 2019 | 03:08 AM
cycle_man's Avatar
cycle_man
Yes just like the manual says make free play at cable-adjust at clutch then adjust at cable. I am wondering if I just have a bad clutch. Do plates get worn from just sitting. The last owner only put 600 miles on it over a 6 year period.
Old Jun 20, 2019 | 05:33 AM
FreedomRider's Avatar
FreedomRider
If you are sure your adjustment under the derby is correct you can adjust the friction zone at the grip by adjusting the cable … to make the friction zone further from the grip make the cable adjuster longer … to make the friction zone closer to the grip make the cable adjuster shorter … you can do this in half turn increments to get it where you like it …
FWIW I use less than a half turn under the derby …
Old Jun 20, 2019 | 06:38 AM
cycle_man's Avatar
cycle_man
That was what I was wondering if I could go closer under the derby. Thanks I will try that.
Old Jun 20, 2019 | 10:23 AM
FreedomRider
You can go closer under the derby ... then use the cable adjuster to put the friction zone where you want it
Old Jun 20, 2019 | 11:15 AM
brownie4412's Avatar
brownie4412
How much oil are you putting in the primary? My manual says too much oil can cause these symptoms.
Old Jun 20, 2019 | 12:04 PM
cycle_man's Avatar
cycle_man
I think it's a quart system I just put the whole bottle in.
