2015 FXBD... DTC 0180 Map sensor failed
Old Aug 6, 2019 | 06:15 PM
Moto37's Avatar
Moto37
Stage III
Default 2015 FXBD... DTC 0180 Map sensor failed
‘15 FXDB, idles at 2500 rpm, poor fuel economy.
Replaced Map sensor, IAC. No vacuum leaks detected.
Throttle set screw properly adjusted. Code returns after being cleared, and condition remains the same. Anybody got a clue? I’m kinda stumped.
Old Aug 6, 2019 | 08:46 PM
nevil's Avatar
nevil
I'm stumped because there is no idle set screw, so I'm thinking that you adjusted the throttle plate stop. That could be the problem. It can throw off the whole map. I've adjusted mine but only when I was setting up my tuner through a laptop.
Old Aug 6, 2019 | 09:43 PM
crusader1xxx's Avatar
crusader1xxx
Unless his definition of set screw means something else? Like that black wheel thingy ( throttle lock) that is under the throttle control housing...
Old Aug 6, 2019 | 09:46 PM
Moto37's Avatar
Moto37
Stage III
You’re correct, that’s what I intended to say. The condition came on suddenly, so I just confirmed it was set correctly. Checked voltage and continuity at both MAP and IAC wiring. Going to test TPS and IAT and then go from there.
Old Aug 6, 2019 | 10:38 PM
Moto37's Avatar
Moto37
Stage III
Default Update
Turned to be a faulty TPS. Problem solved
Old Aug 7, 2019 | 10:16 PM
crusader1xxx
Glad you got it sorted...
knpa762
Jul 26, 2019 07:10 PM
Nanga Parbat
Jul 20, 2018 04:06 PM
Gordon61
The Dyno Room
Sep 30, 2016 04:19 AM
ToBeFrank
Oct 11, 2008 09:20 PM
forestfarm
Jun 4, 2007 11:43 PM
