Rear brake clunking
Old Aug 28, 2019 | 08:39 PM
Cubby89's Avatar
Cubby89
Originally Posted by John CC
Actually, I was going to ask about that. Even with the clutch in, it still drags some. Try it with the clutch out, too. See if there's a difference. You can try a low gear (1) and a high gear (4-6). No need to try them all.
Just rode around the block a few times experimenting. Clunk happens clutch in or clutch out. After trying clutch out a few times I notice that it's actually a really similar sound to when your bike starts to stall. What i mean is when I brake hard no clutch and it starts to shutter and stall it makes a clunk, reeeally similar.
Tried in neutral a few times too. Could not get it to make the clunk. I wasn't able to get into neutral at a higher speed (over 20km/h) but I tried a few times at slower speeds where I'd get it in 1st and it didn't even remotely happen. Now I'm really stumped.
Also for ***** and giggles I taped a rag around my jiffy stand where it contacts the frame to eliminate that as a cause.
Old Aug 28, 2019 | 08:40 PM
Cubby89's Avatar
Cubby89
Originally Posted by Jay Guild
Check your rear pulley bolts. The clunk may be the pulley moving on the bolts.
Checked them. Definitely tight.
But my belt is definitely looser than it should be. I can't imagine that would be what's going on here?
Old Aug 28, 2019 | 09:49 PM
crusader1xxx's Avatar
crusader1xxx
Did you align the power train when you put the new mounts in? You have to...other wise your rear wheel can get mis-aligned and cause all kinds of problems....cause your rear wheel is actually attached to your power train.
you have to understand how the Dyna model is put together...it really is unlike anything else out there. Many have explained it but none better then....Tarik(F86)
here are two distinct halves to a Dyna: The front wheel, fork, and frame are one assembly. The rear wheel, swingarm, engine and transmission are a completely separate assembly. The two assemblies are connected to each other purely by the two rubber engine mounts, one in the front of the engine, the other on the back of the transmission. The top link is really just a stabilizer/locater for alignment purposes, and isn't really a structural link between the two halves. Any and all movement incurred by the engine is directly carried through the transmission to the swingarm and the rear wheel. If the engine vibrates in the longitudinal chassis plane, this isn't much of an issue. If it vibrates left to right, the swingarm and rear wheel move left to right. If the engine swings like a pendulum from the top link, the rear tire actually rolls onto it's sidewalls a little bit, back and forth. The purpose of all the different aftermarket stabilizers is to limit lateral engine movement, while allowing enough longitudinal movement to keep unwanted vibration in check. This architecture explains why a Dyna is much more sensitive to all chassis adjustments/issues than some bikes are... Air pressure, wheel bearings, steering bearings, swingarm bearings, and particularly drivetrain alignment... That's why the same outcome can be difficult to diagnose from bike to bike.
The good news is that when properly setup, a Dyna chassis is actually a very good handling platform.
Old Aug 28, 2019 | 10:36 PM
Cubby89's Avatar
Cubby89
That's actually really interesting and before I started thinking it was in the tranny I was wondering about the swing arm. Just a thought.
By alignment do you mean loosening the bolts and letting it run a few seconds? I did do that. Haven't done anything else. Should I go through the whole alignment procedure? Think that might help?
Old Aug 29, 2019 | 06:08 PM
Cubby89's Avatar
Cubby89
In the transmission forum someone suggested maybe it was transmission wind up and that with higher mileage it can get clunky. Anyone know anything about that? Nothing to worry about? Maybe start thinking about a tranny rebuild?
Old Aug 29, 2019 | 06:18 PM
Coverdog's Avatar
Coverdog
I read your other thread. If I remember correctly you said you had 30,000 km. I would not consider that anywhere near high mileage.
Old Aug 29, 2019 | 07:42 PM
Cubby89's Avatar
Cubby89
Nah 50,000 km
Old Aug 29, 2019 | 11:33 PM
crusader1xxx
Still not high mileage. Power train alignment procedure with inclinometer...look up F86 post on it, he has the best method I have seen so far on doing this....
easiest way way for me to describe it is take the seat off, get the bike level on a flat surface, measure that you are 100% level by putting the inclinometer on the back/cross bone of the frame, zero it out by jacking the bike up or down on one side, I suggest the side stand side, use a small jack under side stand or foot peg...once zero out you know you frame is straight
move to rear wheel and put inclinometer on brake disc...what is your reading? If it’s zero your 100% aligned. If it’s not you have to turn the top engine mount in or out to zero It out. Once it’s zero your now properly aligned.
I usually do this two of three times just to make sure my reading are correct.
Old Aug 30, 2019 | 10:02 AM
WS6 Formula's Avatar
WS6 Formula
Are you missing the rubber bushing?
Old Aug 30, 2019 | 11:51 AM
F86's Avatar
F86
Interesting thought!!!
