What tins fit 2000 FXDWG?
Old Jul 13, 2007 | 02:12 PM
pascowg's Avatar
pascowg
6th Gear
Default What tins fit 2000 FXDWG?
I asked my local HD dealer but didn't get a real answer, so here goes:
What years/models tins will fit my 2000 FXDWG? I thought it was a simple question...
Thanks.
Mike
Old Jul 15, 2007 | 12:44 AM
pascowg's Avatar
pascowg
6th Gear
Default RE: What tins fit 2000 FXDWG?
Uh...is it THAT hard a question?
Old Jul 15, 2007 | 01:51 PM
DYNAMITE 1's Avatar
DYNAMITE 1
Tins that were made for a 2000 wide glide. Wow, that was simple
Old Jul 15, 2007 | 06:11 PM
Rodent's Avatar
Rodent
Never could understand why people call them tins!
There made of steel.
Sounds like the OCC American Chopper hacksmiths.[sm=bicker.gif]
Old Jul 15, 2007 | 06:45 PM
DGlide04's Avatar
DGlide04
The sheetmetal from any Dyna that year should fit, but you'll have to use spacer blocks if you want a narrow glide front fender to fit, due to the triple tree width. Other tanks should fit, but with the WG speedo mounted on the tank, you may have to but a few other parts to make everything fit. From what I understand, pretty much the same frame was used from the mid 90's through 2003 before the change in the 2004-2005 model frames.
The bobbed rear fender used on that year WG was the same one Harley sold to put a bobbed fender on the same year Dynas, so they should all be interchangeable as far at the bolt holes in the struts, etc. Mods for the tail lamp and turn signals may have to be made.
Old Jul 19, 2007 | 03:51 PM
Ianltd's Avatar
Ianltd
Hi,
The fenders front and rear remained the same since the 80's until the rear fender went wide in 06 , the fuel tank however ran from 96 - 2003.
[/align] Hope this information is helpful.
Regards,
Ian
[/align]
Old Jul 19, 2007 | 04:15 PM
pascowg's Avatar
pascowg
6th Gear
That helps alot! Thanks. Now does anyone know if I can use Softail or Fat Bob tanks?
Old Jul 19, 2007 | 07:25 PM
DGlide04's Avatar
DGlide04
ORIGINAL: pascowg
Now THAT would require some major work, but it just might look cool enough to make it worthwhile.
Kozmo
EVO
21
Dec 14, 2017 05:53 PM
jdutour
Sep 22, 2015 02:31 AM
Artlee
Motorcycles For Sale
Apr 7, 2014 12:24 PM
megawatt1
Sep 11, 2010 03:54 PM
sportsterxl50
All Other Models
Jul 14, 2008 03:07 PM
