Transmission fit?
You don`t have to replace a transmission just because it needs to be repaired...
These assemblies are built with replaceable parts, you simply disassemble the transmission, find the problem and fix it.
First disconnect all the shift linkage and make sure it moves freely.
Check the lever at the transmission, see if it moves back to its center point after you move it.
If the shift lever does not spring back to its centered position, remove the top cover from the transmission and take a look at the spring and shifter pawl, they will be on the left side of the transmission.
Nothing will fall apart when you remove the cover...
This is what you will see:
