Dyna shocks
Old Aug 27, 2019 | 10:06 PM
Dyna100's Avatar
Dyna100
Originally Posted by skyrocket22
What do you recommend for the front? I just put Öhlins in back, yes I can also tell the difference in the front now.
I used Racetech Gold Valves with my stock springs. Big improvement. The jarring/harshness of the stock suspension is greatly improved. A lot of people claim further improvement can be had using Racetech's single rate springs. If your budget allows you could opt for a set of Ohlins cartridges. I'm very happy with the Gold Valves.
Old Aug 27, 2019 | 10:30 PM
Bob_fxdb's Avatar
Bob_fxdb
Patriot genesis might even be better than race tech. Double springs that also help with bottoming. Cheaper than race tech with gold valve
Old Aug 28, 2019 | 06:00 AM
OakMountainRider's Avatar
OakMountainRider
Originally Posted by REW13
What's your budget?
Perhaps 500$.
Old Aug 28, 2019 | 08:35 AM
PhillySoldier's Avatar
PhillySoldier
Bitubo Twin Adjustables from DK Customs. Plenty of reviews on them here on the boards
Old Aug 28, 2019 | 09:29 AM
HyperM3's Avatar
HyperM3
I put 12" 444's on mine. If I could do it over again I would do 13", but in something higher end. I hit a small pothole last month at slower speeds, maybe 35 mph, and the jolt was so strong up my spine I heard a slight crack in the base of my skull. I had a minor headache and pressure there for the next 3 days. It went away of course, but fear hitting anything again as Im sure its a weak spot from now on.
Old Aug 28, 2019 | 05:57 PM
REW13's Avatar
REW13
You can get some good stuff with 5 hundred OAK...
Have you done anything with the front?
Old Oct 20, 2019 | 02:51 PM
OakMountainRider
Hello dear Riders,
I ended up with Öhlins 36e on my FXDL and have adjusted them to a "sag",
(i. e. adjusted the preload affecting the distance between the end of the swingarm and the rear
part of the frame, which occurs between a lifted position and a position
with myself on the bike), of 30 mm - thus following the manual which recommends a sag
between 25-35 mm. As the manual is unspecific, both about what bike and what type of Öhlins
shock it is describing, I have a request about a more specific sag distance, and I am
hoping someone here has experience from using Öhlins on a Harley.
For those of you who, just as myself, got tired of feeling bumps destroying the body joints, I
can recomend Öhlins. The difference is amazing and for the first time I can now ride over those awful
bumps without worries for neck pain later.
Any advice about what sag is the best on a Dyna is much appreciated.
Old Oct 20, 2019 | 05:54 PM
DD3's Avatar
DD3
Ohlins 761,their least expensive. Fantastic for me,different springs as I'm 140 lb.
Old Oct 20, 2019 | 06:08 PM
DD3's Avatar
DD3
Originally Posted by OakMountainRider
Hello dear Riders,
My friend ste them up for me. Full tank of gas,my leather jacket ant the small bag I carry. The shocks have 68mm of travel,sag is supposed to be 1/3 of total with me on the bikes,feet on pegs. After setting and riding,we came up with 24 mm.
Old Oct 20, 2019 | 08:48 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Keep it simple. I've been running Bagger air shocks on my 07 Dyna for 8 years and lovein it. Look for take-offs on ebay , 2 schraider valves and get 1 quart if Shock oil 10 w. (With the Low Rider, lowered Street Glide air shocks will work perfectly.) 1st order of business - drain the shock oil out. Remove the air fittings and suspend them UPSIDE DOWN over a catch can. Let then drain for 1 day. 2nd order of business - Refill with 10 w shock oil (fork oil) slowly. I put hose barbed fittings on and refilled 8 oz in each shock with a Mighty Vac. To adjust the air pressure, use a Bagger shock air pump. DO NOT use air hose like filling a tire, it will blow the seals to hell. Run em with 5-8 psi your neck will thank you. I run 5 psi solo and 10 psi 2 up.
