Are you using synthetic or conventional oil in your motor? When I had my RK with the 96" running synthetic the bleed down was awful making the knock sound like piston slap. An 'ol biker friend told me to swap the oil out with a good conventional oil and wait a few hundred miles. Told me to be patient and it would quiet down. He was right, it took about 300 miles and it quieted right down and stayed that way. Never used synthetic in the crankcase again in any of my bikes ever since. Dave ('ol biker dude who has since passed away) stated vtwins hate synthetic oil cuz it thins out too much causing all kinds of noise issues. FYI.
I run synthetic oil in everything I own and have yet to have any issues at all with any of my rides. 2009 Jeep (156,000mi.) 2016 Mitsubishi (85,000mi.) HD SuperGlide (36,000mi.). If you have a noise I doubt its caused by syn. oil.
Easy way to pin point the noise - long screwdriver stethoscope. Point of screwdriver on engine, end of handle against your ear. LISTEN for the noise. Move it around the engine till you find it.
X2
I use this method all the time, it works great.
Pull the exhaust and cam cover asap, inspect the cam chain tensioners (especially the inner one). Or spend a lot of time chasing something else. When you hear hooves, look for horses, not zebras. Whatever you do, don't continue to ride it until you've determined the cause.
I generally try to find the general area that noises are coming from before tearing into an engine. It makes it a lot easier to find the problem when you have a general idea where it is coming from. The screw driver method works well but a piece of steel automotive fuel or brake line works great. What ever you use find out affected area before you start tearing into, it will save you a lot of work and trouble down the road.
problem I have is my noise only happens when the motor is under load........kinda hard to do the stethoscope while feathering a clutch or worse, going down the road.
First thing I I would look at would be the octane of the fuel. You may be going past the "pinging" phase and into pre-ignition. The other thing to check is carbon build up That will cause hot spots and pre-ignition. I have also seen carbon build up on piston tops hitting the combustion chamber causing a knock.. A dose of sea foam has helped in those cases.
I don't really hear a knock as much as I hear a tap, they are totally different. check your exhaust header primary nuts/studs for looseness, or blown out gasket.........
