Cleaning after oil change
Old Jul 16, 2007 | 10:59 AM
rewog's Avatar
rewog
Default Cleaning after oil change
What cleaners are allowable to remove oil on the motor mt and case(black mat) after removing old oil filter?
Old Jul 16, 2007 | 11:14 AM
wbogley's Avatar
wbogley
Default RE: Cleaning after oil change
Simple green is a great product! Get some. It works great to remove oil from bikes. It is very mild as well.
Old Jul 16, 2007 | 11:43 AM
96 Wide Glide's Avatar
96 Wide Glide
Do you use that simple green full strength, or dillute it with water first?
Cheers... Ben.
Old Jul 16, 2007 | 11:46 AM
wbogley's Avatar
wbogley
I use it straight from the spray bottle. You can dilute it if you have a big job.
Old Jul 16, 2007 | 12:35 PM
AZ Rider's Avatar
AZ Rider
I use brake cleaner.
Old Jul 16, 2007 | 01:45 PM
docsg's Avatar
docsg
I guess I'm crazy but I simply douse (not saturate) an old hand cloth with gas and wipe the oil off the mount and black part of the case.It also works well to wipe up the few drips that get on the garage floor. I ride the bike until it is around or at normal operating tempature and then let it sit for about an hour. I then let it drain (straight up on my jack) for 10 - 15 minutes. Even doing this, I'm only able to put about 2.6-7 quarts back in to get it to register at the proper mark on the dip stick. The service maual says this is normal for a "wet" bike. However, at my last oil change at the dealership they put in 3 full quarts. My bike always registered slightly overful at both the hot and cold settings but they told me not to worry about it. If I were them I would just keep the extra at each oil change they do and every 5 - 6 changes they would pick up a full quart of oil and at $9+ retail, that would add up over time.
Old Jul 16, 2007 | 02:09 PM
AZ Rider's Avatar
AZ Rider
Man, don't use gas. There are so many other cleaners and solvents to choose. Just suggesting.
Old Jul 16, 2007 | 02:35 PM
voyager1's Avatar
voyager1
explosion time.
Old Jul 16, 2007 | 03:19 PM
rocklayer2's Avatar
rocklayer2
I second the brake cleaner. works great, drys quickly
Old Jul 16, 2007 | 05:35 PM
06dynablack's Avatar
06dynablack
brake cleaner does work great but it is detrimental to rubber and plasic etc.After reading the brake cleaner can decided not to use it for that in that area. your rubber mnt is right there also the clutch cable
