Steetbob
Old Nov 9, 2019 | 07:07 AM
Nibbs's Avatar
Nibbs
Stage II
Default Steetbob
Hi all help needed.
I have a 2016 Steetbob and it has stopped working.
I have no power going to ignition/acc. Battery OK, changed fuses and checked ground cables but still nothing.
Happened after air filter cleaning. Bike was running a bit rough before air filter clean.
Thanks
Old Nov 9, 2019 | 12:03 PM
nevil's Avatar
nevil
Be more specific. By "not working" do you mean it won't turn over, or will crank and doesn't start, or starts and dies? How many volts does the battery show at rest and under load? What kind of mods does it have?
Check the plugs and wires to the coil, and see if it threw any codes. Are you getting spark to both cylinders?
Old Nov 9, 2019 | 12:34 PM
Nibbs's Avatar
Nibbs
Stage II
No electrics whatsoever no electrics to instrument panel/ignition, light, indicators.
Battery charged to 13v bike won't start to load test.
power going from battery to starter and I changed fuses too.
Old Nov 9, 2019 | 01:08 PM
nevil's Avatar
nevil
Then charge the battery fully and take it to get it load tested.
jahwarrior007
Electrical/Lighting/Alarm
Sep 6, 2017 11:12 PM
ByronL
11
Sep 5, 2016 08:07 PM
Halverson19
Jul 19, 2016 11:37 AM
hdstevie
May 12, 2015 07:42 PM
ratWynx
Engine Mechanical Topics
Sep 18, 2010 03:06 PM
