FXR Brake fluid
Old Nov 13, 2019 | 11:53 AM
1Reaper's Avatar
1Reaper
Default FXR Brake fluid
I'm replacing the rear brake switch and need to know what kind of brake fluid I should use on my 89 FXR.
THANKS
Old Nov 13, 2019 | 12:00 PM
John CC's Avatar
John CC
I would use DOT 4 LMA (Low Moisture Activity). That said, if you have DOT 5 (not 5.1) in there now, you must continue to use DOT 5 unless you completely disassemble and flush the system.
Old Nov 13, 2019 | 12:16 PM
robarosa's Avatar
robarosa
If the reservoir cap has the fluid type noted, I would stay with that to avoid future problems.
Hundskrüppel
Feb 6, 2018 01:41 PM
Ipara
Mar 31, 2016 01:14 PM
01fxdxt
Evo Era Parts
Aug 12, 2015 05:23 PM
ssmith579
EVO
Aug 21, 2014 06:11 AM
dirtbag1
EVO
Oct 22, 2013 09:41 AM
