Tuner advice
Old Jan 21, 2020 | 12:02 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by Bob_fxdb
Ok, I thought the definition of a piggyback is something that had to be connected to the bike at all time, like a power commander.
It is.
Old Jan 21, 2020 | 01:22 PM
Jay Guild's Avatar
Jay Guild
It is, but to get the wide band sensors for the PV the Auto-tune module is permanently installed between the O2 sensors and the ECM. While you can still disconnect the PV the Auto-Tune module can not be removed.
Originally Posted by GearheadMike
The PV (Power Vision) is a flash tuner. When you add the wideband sensors, they help it build more accurate AFR tables to flash to the ECM. Same as a dyno, they shove a wideband sensor into the exhaust to get an accurate AFR. I believe the Thundermax operates the same way? The wideband builds tables, which you flash to the Thundermax ECM, or is it real time? Either way, I am a fan of a wideband system.
Almost, the PV has target AFR maps that it loads in to the ECM so it can control the fuel flow based on what estimates of fuel is needed. If the wide-band O2 sensors detect a 14.0 AFR and your target is 13.2 then it will modify the MAP in the PV to around 12.7 (even though the target is 13.2) and you have to program the new MAP and see where the measured AFR is after the modification. While the PV knows what the target is, it is tricking the ECM to either lean or richen the AFR based on how close to the target the PV sees. The ThunderMax has the O2 sensors directly fed in to the ECM and has the target AFRs and measures the exhaust in real time will adjust the fuel output to hit the targets as defined by throttle position without actually lowering targets or requiring any user interaction. The only user interaction is if you want to adjust the targets to fix an issue or save the MAP that has been adjusted by the auto-tune.
Old Jan 21, 2020 | 01:54 PM
cggorman's Avatar
cggorman
In general, the best tuner is the one that have the most users. That way you get more diverse maps that people shares with each other.
I have never seen two modified/custom engines that have identical tuning parameters. Sharing maps/parameters is only helpful (IMO) to get a useable baseline onto which you build your final tune.
I figure the best tuner is the one that has the capabilities you need and has an interface you can effectively operate. I am perfectly comfortable using a MegaSquirt and Tuner Studio. Many are not. Give me a PV, Thundermax, FAST, Motec, etc and I'd have to spend days learning the ins and out. Do that to a dyno shop and they either turn you away or charge you MEGA bucks for their lelaening curve.
So...if you plan to have a shop do the tuning, make sure they are familiar beforehand.
Old Jan 21, 2020 | 09:34 PM
bluelinerider's Avatar
bluelinerider
I'm learning quite a lot from all the feedback, so THANKS TO ALL! I've been in contact with FuelMoto and they're offering a pretty sweet deal on their Micro EFI Tuner. I'm not going to ever do anything more than maintenance on my stock mill, so cams and big bore stuff isn't in the works. I'm pretty satisfied with the small upgrades I've done (intake and exhaust), so I'm leaning pretty heavy on the K.I.S.S. method for my situation and considering going with their "hook it up and ride" device. You guys, obviously, have a much better grasp of tuning, mapping, controllers and piggybacks, ECU's, programs and all that than I do, so I totally appreciate the technical advice. There was a time that I thought I could (maybe) at least keep up, but damn, man... there are so many different devices for what seems like the same basic thing- jetting.
So...that said...anybody have any experience with the Fuel Moto Micro EFI??? FM's service seems to be pretty outstanding already (I have taken that advice from the forums, too) and God bless Paul over there, he's been answering all my questions without fail (even though he's probably shaking his head saying "not this guy again." haha). Thanks again guys...
Old Jan 21, 2020 | 09:43 PM
Jay Guild's Avatar
Jay Guild
Glad they are giving you what you want. Good service is important.
Old Jan 23, 2020 | 06:03 PM
Ghost_13's Avatar
Ghost_13
Power Vision and a proper dyno tune - otherwise you're wasting money and effort
Ghost
Old Jan 24, 2020 | 06:08 AM
Bob_fxdb's Avatar
Bob_fxdb
Yes I agree with you, that is what I meant. A good baseline is needed.
I think people here are getting to advanced, I appreciate it tho(!), but I don’t think it is what the op is looking for, or am I wrong?
It’s bad business for any shops to turn down a job for just a different tuner box or be angry. It’s 2020 and the technology in those tuning boxes are already super old. It’s about time to learn new stuff or else you just standing still. This of course applies to shops and not individuals. We have the freedom to chose what we want, shops need to adapt.
If the owner is finished with their engine work and don’t plan to do more work, by theory, can’t they just tune the engine on a dyno and don’t need to get a tuner box? Or will the engine change over time?
Old Jan 24, 2020 | 02:16 PM
HotRod917's Avatar
HotRod917
Originally Posted by GrittyBurns
Thanks for combining from the other posts. It's strange how V&H would put a blatant disregard for customer service in writing like this...
Yeup..those are the facts. If i were in the US, I would have surely walked into V&H n said WTF.! to their faces.
The answer is right there in ur own statement. Like a "good baseline" Map, a good EFI flash tuner is the quintessential tool which goes a long way in achieving a smooth and efficient engine even in stock form. Ease of use, flexibility, compatibility(long term), support are generally what everyone is looking for.
Isn't it a natural human tendency to improve in life through learning. The OP is here for the same reason, maybe just a tune/tuner for now..So as advance users we always suggest the best for long term use based on facts, Plus always tell the person to speak to a reputed tuner shop Like Fuel Moto, Hammer Performance etc for the best advice from the pro's.
Not even the EV's are kinda new stuff anymore. The ICE and the basic tuning parameters to make it more efficient/powerful remain the same. The only technology in the "New Stuff" is the marketing BS technology.
Also the reason why we ask ppl to speak to a reputed tuner shop.
Yes and yes
Old Jan 24, 2020 | 04:03 PM
bluelinerider
You're not wrong...I'm handy with a wrench but not as much with a computer. I appreciate all the advice on tuning and maps and all, but I'm not tech savvy enough for all that. Hell, I don't even own a laptop, so "benchtop dyno tuning" is something I have to leave to the experts. I just need to be able to plug it in and make it go vroom. I should have my FM Micro EFI today, so I'll post back once the bike is off the lift and let y'all know how this simpleton likes it. I still need to find some O2 eliminators, so if anyone knows where I can get some from the US, let me know. The only ones I've been able to find are on ebay from the United Kingdom.
Thanks again to all!
Old Jan 24, 2020 | 05:38 PM
cggorman's Avatar
cggorman
I don't disagree, but there are dozens of tuners, each with their own software. Yes, the principles of tuning remain the same but there are countless variations of installed sensors, not to mention the design of the software itself.
I've no doubt any competent tuning shop could figure out whatever customer x brings them, it takes time to learn not only the hardware installed on their machine, but the new software as well. If they have time (small/no backlog) amd the customer is willing to ante up, they would be foolish to turn down the opportunity. However, most decent shops are booked out quite a ways and most customers are cheap (in a bad way). Hence my recommendation to use the systems your favorite tuning shop prefers. It's the fastest, easiest, and probably cheapest overall option...save some simple piggyback options that wouldn't likely see a shop anyway.
DIY away (I certainly do!), but know that a pro may well penalize you for going "off book". Been there. Paid the bills. Hah!
