06-up real wheel measurements
Old Feb 2, 2020 | 01:31 PM
M4dm4x's Avatar
M4dm4x
Default 06-up real wheel measurements
Hi, I’m trying to adapt a ninja 650 rear wheel to my dyna and Im trying to anticipate what offset trans sprocket I’ll need. Can anyone with a chain drive measure the distance from their sprocket to rim lip, and let me know what spacer and front sprocket they’re using Or does anyone know the measurement from the plane of the pulley side the hub to the plane of the rim lip?
Old Feb 3, 2020 | 11:12 AM
TOE_CUTTER's Avatar
TOE_CUTTER
What is the width of the Ninja rim, and the size of tire you’re planning on running?
Dave
Old Feb 3, 2020 | 11:23 AM
Blue Bob's Avatar
Blue Bob
Dave
Looks like a 2020 ninja 650 is using a 160/60 x 17 Rear tire:
Old Feb 3, 2020 | 11:25 AM
M4dm4x's Avatar
M4dm4x
Dave
it’s a 4.5” rim and I plan on running a 160 tire on it. My primary concern is that it’s a Cush drive hub so I can’t really space out the rear sprocket, I can only adjust the trans sprocket offset or offset the wheel I guess, although I hope to either center it in frame or run stock offset.
Old Feb 4, 2020 | 09:58 PM
TOE_CUTTER's Avatar
TOE_CUTTER
Maybe this will help:
https://www.hdforums.com/forum/dyna-...2006-dyna.html
Dave
Jean-Philippe Taschereau
Wheels/Tires
Apr 17, 2018 12:47 PM
JeffJA
Jun 12, 2017 08:36 PM
Egldr05
Apr 3, 2013 11:41 AM
fogcity123
EVO
24
Jul 2, 2010 04:37 PM
Shrug
May 3, 2008 01:37 PM
