Andrews 57H Cam Advice
I currently have a set of Andrews 57H cams in my bike. Just ordered a set of Woods 222's over the weekend to replace the 57's. I liked the 57's from 3000rpm on up, but felt they were a little weak on the low end. I'm finding I don't rev much past 5k rpm's, which is where these cams really shine, as they pull to redline. From the scouring of dyno charts, the 222's look like they fit the bill. Almost went with the Andrews 48's, but from all the dyno charts I've seen, the 222's have a very similar low end to the 48's, but the 222's carry out a little farther up the rev range.
Once installed, the bike will be visiting my local tuner.
At the present time I have a 4 degree advanced gear in it as well. I can stay with stock 103's. It has a lopey idle which sounds great. I also built a set of 2-1 pipes for the bike. nice low idle but she barks when ya twist the wick, I have the TTS tuning module and am planning on a 106 S&S pistons and my cylinders bored and honed to fit the pistons. I want to also have my heads done to match. the throttle body will be bored and 4,9 injectors to be added to the mix. My tuner of choice was taught by Steve Cole and resides in my home state.
I have spent the past few days thinking about what you posted. You are right, but you based your results on a 107 at sea level. I agree with taking out the 4 degree advanced gear and put the original gear back in it. I also spoke with S&S about the piston I want to use. Its a flat top 106 piston with valve cutouts that have a CC of -1.5 of Piston Dome Volume. I heard back from my head porter and he said that a compression ratio of 10.2 to 10,5 would be fine if the tune was right, and he could set my head CC's to what ever I wanted, based on info we exchanged. I want my heads to be set at 86 CC's so I can use a .030 head gasket. Now for my tuner, this guy specializes in the TTS tuner that I have. In fact he worked with Steve Cole when TTS was involved with figuring out the base maps for the M8. He was the one that told me that the Andrews 57 could handle 10.5 compression ratio, I am looking now at 10.3 compression ratio. And this tuner lives 150 miles from me. Now I also understand that none of the above will come to pass if my crankshaft runout is greater than 005. That's what a few engine builders have told me. If that's the case it's time to buy a used crank and send it to Darkhorse and let them do their magic on it. And no, I am not an engine builder at all, so I asked for advise and I am posting now but do not want a pissing contest and I see you have an Andrews 37 in your bike. I also saw that you set your compression ratio to 10.0. Now is your bike a bit doggy down low? My 57 in my 96 is a bit choppy but it isn't that doggy down low either, I am in the process of buying parts for this build and I have a long way to go. I appreciate your comments though and your info is duly noted. Thank you.
honestly for what youre trying to accomplish there are much better(tuner friendly) cams that were designed to see higher compression. Its my understanding that the 57 was developed as a drop in.
