Diagnosing 2011 FXDB issue
Old Apr 24, 2020 | 09:01 AM
Srrmc's Avatar
Srrmc
Thumbs down Diagnosing 2011 FXDB issue
Just got the bike(2011 FXDB, with 42K on the odometer, replaced the motor mounts "amazon", now when i hit a bump it sounds like it is bottoming out. Also, when i hit the rear brakes the bike shudders not a brake shudder, but a seat of your pants shudder. Anyone have any ideas.
Old Apr 24, 2020 | 10:53 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Check the gas tank bolts, front and rear, to see if that stops the bottoming out sound. Check the brake pads on the rear first, if they're okay see if the rotor needs to be replaced.
Old Apr 24, 2020 | 11:06 AM
Srrmc's Avatar
Srrmc
I was thinking that the motor mounts were of inferior quality. Could this be coming from a bad motor mount?
Old Apr 24, 2020 | 11:45 AM
nevil's Avatar
nevil
Yes, especially if it's some off brand Chinese crap from Amazon.
Look at the mount to see if any of the rubber is damaged or if the mount wasn't shimmed correctly.
Sometimes the tank bolts don't need more than a slight tightening, so use a socket or a wrench on them.
Old Apr 24, 2020 | 01:22 PM
slimer's Avatar
slimer
My previous bike was an 06 Superglide. When I bought it in 2017 the front motor mount was shot. I thought I’d be proactive and change both. Front went on without any problems. Rear mount was on backorder from JP, so I rode for about a month with just the new front mount. What a difference! Less overall vibes and rode well.
When the rear mount arrived, it was a PITA to install. Seemed like it didn’t line up right, no matter what I did. Finally got it installed and had the same symptoms as you. Swapped the old mount back in and never looked back. Ran fine til the day I sold it.
If the other posts’ suggestions don’t fix it, maybe you could reinstall the old mounts, one at a time, to see if you can isolate the issue.
Old Apr 24, 2020 | 02:12 PM
Srrmc's Avatar
Srrmc
me = new mount throw the old ratty ones away!!
Old Apr 24, 2020 | 02:16 PM
Srrmc's Avatar
Srrmc
oh well, just went to get them out of the trash....too late. At least Amazon is taking the Chinese ones back
Old Apr 24, 2020 | 09:17 PM
TexasScooterTrash's Avatar
TexasScooterTrash
I recommend the front and rear motor mounts from Drag Specialties, really firm, hard rubber. Got 4 years and no deterioration. I'm also using DS rear motor mounts in my Wife's 04 Sportster.
Old May 1, 2020 | 10:56 AM
Srrmc's Avatar
Srrmc
Default hd mounts
just replaced both Amazon mounts with HD mounts...problem solved
drspencer
Apr 27, 2013 11:02 AM
stevil66
Wheels/Tires
Mar 4, 2013 07:47 PM
stevil66
Wheels/Tires
Mar 4, 2013 07:24 PM
Black Tiger
Aug 2, 2012 06:54 PM
Mars1
May 1, 2012 06:45 PM
