fork preload caps
Old May 5, 2020 | 04:32 PM
Yaborin's Avatar
Yaborin
Default fork preload caps
Hi everyone,
I have an FXDLS dyna and I would like to put fork caps with preload, the stem is 49mm, but most websites tell me that the 49mm caps do not fit on FXDLS but only on normal low rider FXDL.
Isn't the fork the same only in a different color?
Why do they say they're not okay?
Only the RSD site tells me that theirs are fine .... I don't understand ...
Do you know anything about yourself?
Sorry for my writing but I use google translate.
Thank you all
Old May 5, 2020 | 06:20 PM
multihdrdr's Avatar
multihdrdr
Because the FXDLS uses a Cartridge on one side and it attaches to the Stock Cap
Old May 5, 2020 | 06:38 PM
Yaborin's Avatar
Yaborin
So you say that one of the two caps is connected to the cartridge?
I understand right?
Why does RSD say they are doing well?
Old May 5, 2020 | 06:53 PM
multihdrdr's Avatar
multihdrdr
I understand right?
Yes, that's what I'm saying
Provide a link to the RSD versions. They are probably listed incorrectly
Old May 5, 2020 | 07:20 PM
Yaborin's Avatar
Yaborin
Thanks for paving the way for my problem.
So is there a kit for my fork?
Bitubo makes a kit with cartridges, can that be fine?
Old May 5, 2020 | 07:23 PM
multihdrdr's Avatar
multihdrdr
Are saying you want to use Bitubo cartridges in your FXDLS forks?
Old May 5, 2020 | 07:46 PM
Yaborin's Avatar
Yaborin
I ask if they can be fine or if they are only for FXDL ..... I like them a lot..
Old May 5, 2020 | 07:49 PM
multihdrdr's Avatar
multihdrdr
It depends ... do you have a link for the Bitubos?
Old May 6, 2020 | 12:52 AM
Yaborin's Avatar
Yaborin
Here:
http://www.bitubo.com/Bitubo/cms/ENG...t/33-jbh1.html
they always do this for FXDL, but I don't understand if I can use it.
Old May 6, 2020 | 06:33 AM
multihdrdr's Avatar
multihdrdr
Well, no matter what, you'll be able to use those cartridges by replacing some of your existing Harley Cartridge side parts with parts that are same as used on the other side.
I'll look at the instructions later today and comment further
