School me on fork tube extensions
Old May 14, 2020 | 05:46 PM
multihdrdr's Avatar
multihdrdr
Since you quoted me, I'll clarify and edit the last part for anyone reading because one wouldn't have to use fork tube extensions as I stated above, but it's still custom work ...
You would have to make new Longer lower section or make an extension and Mod the existing, then add a same exact spacer right above the Top-Spring. Effectively shifting everything up by whatever lengths you had made and maintaining the same exact travel
So you're using 25.5" Gold Tubes?
Old May 14, 2020 | 05:54 PM
Nitrochicken's Avatar
Nitrochicken
Correct. Yes sir.
Old May 15, 2020 | 08:26 AM
beanoboy's Avatar
beanoboy
No, you can't use Fork Tube Extensions with those Progressive Monotubes
You can physically attach some extensions, but because those Cartridges are a Finite Max length you would gain No Height and the extra length would be inside the slider and just reduce your fork travel
That's why they make different versions (lengths) for the NON-Wide Glide Dynas and then the Wide Glide
Not doubting your info. but these extensions/slugs are solid, so how does the length not increase ? The 'innards' of the forks are still at the same length and your only extending the outside of them. Again NOT challenging you.
Old May 15, 2020 | 08:38 AM
Uncle Larry's Avatar
Uncle Larry
A fork tube gets rigidity and strength by being one piece. By making it 2 pieces, it's a stress point and only as strong as the threaded joint. Not to mention the way those threads are formed, either rolled or cut. Then consider that the wall thickness of the tubes and the extensions may be of different thicknesses. If proper radius or filet is not there then stress cracks form and eventual failure. So, machining and engineering aside, a piece of tubing with an extension is severely weakened. While riding a bike those forks flex and bend a lot whether you realize it or not. Not hard to picture the outcome if your fork legs break while putt'in down the freeway and sooner or later you end up badly.
Old May 15, 2020 | 09:05 AM
multihdrdr's Avatar
multihdrdr
First, what do you mean by "solid"? ... a Solid Slug or a (solid) Tubular Extension?
You could physically attach a Tubular extension, but Not achieve the desired results.
Using a solid slug is Not possible
... in regards to these "Progressive Monotubes"
Old May 15, 2020 | 12:11 PM
beanoboy's Avatar
beanoboy
My bad, didn't read your post properly, monotubes obviously are different.
Old May 15, 2020 | 12:52 PM
ABQ-Jammer's Avatar
ABQ-Jammer
I've seen solid tubular extensions as well. It fits into the top triple tree, and screws into the top of the fork tube, so the fluid would still stay in the same space as usual, so any cartridges or springs would not need to be changed or extended. However, most that I see now are those which are hollow, or with a small section in the middle that is still solid, and come with a spacer to go in the bottom, and a small tube extension which may or may not have a solid center, but which would probably require at least topping off the fluid there.
NWTruck
Oct 9, 2024 06:26 AM
hyrax222
EVO
Mar 31, 2015 08:55 AM
jlilnc14
Aug 22, 2012 07:16 PM
hdpedro
Dec 15, 2010 09:51 AM
lowriderrob
Oct 21, 2009 02:31 PM
