Carb problems
Old Jul 4, 2020 | 09:03 AM
Boomer56's Avatar
Boomer56
Stage I
Default Carb problems
I have a 1998 fxd ancient had a bad pet **** replaced it and have gas going to carb but won’t start without starting fluid will not stay running I’m thinking stuck float
Old Jul 4, 2020 | 10:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How long since the bike last ran?
We can guess what the problem is until the cows come home, but the way to solve the issue is to remove, disassemble and clean the carb.
Old Jul 4, 2020 | 11:56 AM
nevil's Avatar
nevil
Since you suspect the float, just check it out. Who knows what else you'll find in the bowl.
Old Jul 6, 2020 | 09:33 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Did it run before you replaced the petcock? Replaced with a stock petcock? Did you check the carb bowl, was gas in it. A dry bowl takes a little time to fill up, then use the enrichener **** to help start the cold engine. If not, the carb may need a good cleaning, may have some varnish in the little orifices.
pieisgood
EVO
22
Apr 17, 2015 10:03 PM
Mcnasby
Sep 8, 2012 12:47 PM
randybecker
Sep 14, 2011 11:29 PM
wishiwasturbod
Mar 31, 2011 11:45 AM
wob925
Ironhead
Sep 1, 2007 02:23 PM
