ok so doing away with the stock 99 wideglide handle bars, using 6" risers and straight drag bars. So my front brake cable has mostly hard lines straight down and the uses small amount of hose
The stock break line is way too long, so what type break line do I need to get? All in all its dropping about 8 to 8 1/2 inches
If you go with Magnum cables you can get a longer hose than you need, then get a BYO (build you own) end to cut the hose to the desired length.
I have some but haven't used them yet. YouTube makes it look like a 5 minute modification
I used these Goodridge hoses from JP Cycles when I put dual-disk on my SB, the fittings make it simple and all you have to do is measure the lengths you need and what connectors and bam zip-zang you're in business!
I used the black parts but I imagine they have non-black if you want.
