30K Service, Steering Head Bearings
Old Jul 25, 2007 | 03:15 PM
MikesWideGlide98's Avatar
MikesWideGlide98
Default 30K Service, Steering Head Bearings
I have the 30K service coming up and had a question about the steering head bearing service. The manual shoes under the service chapter the disassemble and lubricate the steering head bearing. When reviewing the steering head bearing section of the manual it states that as soon as you remove the dust cover you must replace the bearing. Which is it? Grease it or replace?
Old Jul 25, 2007 | 03:48 PM
Trout's Avatar
Trout
Default RE: 30K Service, Steering Head Bearings
I always grease them rather than replace them. They are standard issue Timken tapered roller bearings. Just clean, pack and replace. The only kicker is that the lower bearing is pressed on the shaft. You cannot really clean and pack it without pressing it off. If you go to the trouble of pressing it off, then just pop the $15 for a new bearing and race (my opinion). I just do my best to shove some grease inbetween the race and retainer with the bearing in-place. If you keep them reasonably lubed and adjusted, then they will last the life of the bike. Heck, the exact same bearing will last 150000+ miles on the front hub of an automobile where it's subject to a much tougher life than in the steering head of a Harley.
Old Jul 25, 2007 | 04:43 PM
kensim's Avatar
kensim
sounds like another money grab from harley,all bearing and seals can be bought heaps cheaper at a bearing supply place.
Old Jul 25, 2007 | 04:57 PM
Trout's Avatar
Trout
I just guestimated the price. My point was that the bearings are relatively cheap, but it's really a mootpoint unless the bearings have been subjected to hardlabor on the seashore.
General Hangover
Jun 29, 2019 10:40 PM
AussieDog
2014-2024 Touring Models
Sep 30, 2018 08:45 AM
anthony_b.
Jun 26, 2013 06:57 AM
Steel Wheels
Jan 30, 2012 07:00 PM
Boomer422
Aug 28, 2006 04:10 PM
