Dyno or fuel Commander?
Old Jul 25, 2007 | 07:31 PM
Macksun's Avatar
Macksun
5th Gear
Default Dyno or fuel Commander?
I have an 06 Bob with a stage 1 and SEII slips ( Big City Thunder Baffles),
Do i need some kind of fuel commander or will just a dyno do?
Runs good, slight popping on decel, backfires if i dont shift cleanly.
Old Jul 25, 2007 | 08:11 PM
6165hd's Avatar
6165hd
Default RE: Dyno or fuel Commander?
Anytime you alter the stock settings on the efi bikes, through exhaust system etc your going to need to a download or SErace tuner with a dyno. You altered your bikes ability to read the proper fuel and air flow combination for your new set up it.Not surewhat fuel commander does, but I believe its a spin off of theSE race tuner and not as expensive.
I had the pop and back fire issueon decel and the dyno, racetuner fixed it. It may have been resolved because of a different issue but my dealer didnt say differently.
Old Jul 25, 2007 | 08:46 PM
6165hd's Avatar
6165hd
FOUND THIS INFO ON THE FORUM ... This may help with some questions to your problem.
One of the most common problems that people complain about is the spit-cough-pop from the carburetor as a Harley Davidson motorcycle goes from idle to Âź throttle. This can occur on any motorcycle, any carburetor, but seems to happen most often with the stock CV Keihin carburetors used on the newer (90 up) Big Twins and Sportster models. This condition is not only annoying, but can cause the Harley Davidson motorcycle to stall dangerously at stoplights, and can damage intake seals parts. It is even possible to ignite oil or gas residue in the air cleaner causing a fire! If your Harley Davidson motorcycle has these symptoms, there are several causes and several easy fixes.
Common causes of motorcycle carburetor spit are as follows:
Problem:......................Solution:
Fouled plugs................Change motorcycle plugs, check gap.
Intake leak..................Spray manifold/head seals with carburetor cleaner, listen for RPM change.
Timing incorrect...........Check timing with light, lube/replace advance weights if used.
Idle mixture incorrect....Adjust low speed mixture screw/re-jet low speed circuit.
Accelerator pump bad....Remove air cleaner, check squirt, check diaphragm.
Bad coil or wires...........Check coil & wires with an ohmmeter, replace if bad.
Any of these can cause the problem, but luckily all are easy to fix.
We have found that the EPA lean setting of the carburetor is too lean for most applications. Through trial and error, we have settled on the #45/46 pilot jet as the best starting point for most engines.
The #42 used in most Harley Davidson motorcycle models is to lean to adjust out with out turning the screw so far out that it is no longer affecting flow.
Old Jul 26, 2007 | 03:06 PM
Macksun's Avatar
Macksun
5th Gear
So will just getting it dynoed be enouph?, aint got the cash for dyno and race tuner right now
Old Jul 26, 2007 | 03:29 PM
cardboard's Avatar
cardboard
If you deceide you want to go 1st class get a Thundermax with Auto Tune.
MNPGRider
Oct 21, 2012 03:35 PM
MNPGRider
Aug 23, 2012 05:51 PM
JVCap
Jul 8, 2011 07:06 PM
HDF Tech
Engine Mechanical Topics
Feb 4, 2006 08:46 PM
HDF Tech
Jun 28, 2005 12:41 PM
