For $700 . . . HELL NO. Been running Drag Specialties motor mounts front & rear. The rubber is a lot harder than OEM and really stiffens the motor/trans to improve cornering.
i have tried oem ,drag specialties and now i am running custom cycle engeneering but there is still some bad vibrations, done alignment,changed clutch bearing,changed compensator, primary chain. etc but still vibrations. so i what to do
Dont know if youre serious or trying to be funny.
Anyways, what kind of vibrations is this? Describe more.
i am serious about this, vibrations start at about 1700 rpm to around 3200. When acelerating all gears, when going of the throttle noting until about 1800 to 1500 heavy like insane handlebar shake. Handlebar and seat, not fotpegs. When you ride and put your hand on front cylinder you can feel it shake hard, alomst notting rear cylinder.Bike is almost unridable do to vibrations, it got this way after i changed to cce mounts. Contacted cce about it but they don t even answer....
Sorry, the first comment wasnt directed to you.
I also got a heavy vibration after swapping out motor mounts. Extreme vibration on lower rpm like yours. The problem was the engine kept hitting the rubber on the new rear mount. I could easy see where the engine was hitting on the top rubber. Swapped it with the old mount and vibration was gone. It could be that? I run Sputhe stabilizers rear and front.
