Dyna Strut Bolts?
Old Aug 5, 2020 | 08:22 PM
bulldog1776's Avatar
bulldog1776
Default Dyna Strut Bolts?
I bought a set of ARP strut bolts for my 05 wide glide. It came with 4 bolts,4 accent rings and 2 hex nuts.
https://www.imzzelite.com/shop/motor...r-strut-bolts/
My question is, why are only 2 hex nuts needed? Which 2 do I put them on? The 4 washers go on the outside of the fender correct?
Thanks.
Old Aug 6, 2020 | 09:00 AM
twincam10353's Avatar
twincam10353
Thanks.
DId you call Imzz? They should be able to set you straight.
Old Aug 6, 2020 | 12:02 PM
Rapidfire1's Avatar
Rapidfire1
Inside fender supports on my street bob are threaded and don't require nuts on the forward portion. I would check to see if yours is the same.
Old Aug 6, 2020 | 12:12 PM
bulldog1776
Thanks. All 4 of yours dont require nuts or 2 of them?
So far imzz will not answer the phone or email.
Old Aug 6, 2020 | 12:24 PM
Rapidfire1's Avatar
Rapidfire1
The front "nut" portion on the front of both fender supports is built in, only the rears require a separate nut.
Old Aug 6, 2020 | 01:11 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Go to Ronnies' HD, parts. they have illustrated parts breakdown for your bike and all others. Look this up and mark as a "favorite" in your computer.
Old Aug 6, 2020 | 04:14 PM
bulldog1776
For some reason I cant find that diagram on ronnie's hd.
Old Aug 6, 2020 | 07:14 PM
Coverdog's Avatar
Coverdog
http://partsfinder.onlinemicrofiche....R-GLIDE%AE-(GM)
Old Aug 6, 2020 | 07:18 PM
bulldog1776
Finally figured it out and got them installed. The bolts closest to the gas tank on mine needed nuts, the back 2 didnt.
Thanks guys for the help.
AJ88V
Jun 6, 2020 07:07 PM
machm1969
Jul 18, 2014 06:03 PM
flhxmc
Feb 19, 2013 01:32 PM
PKellyMc
Nov 7, 2012 05:54 AM
Wrongturn
Feb 20, 2009 10:47 PM
