Trouble code
Old Aug 26, 2020 | 03:53 PM
GreginWV's Avatar
GreginWV
Default Trouble code
my 2010 fxdc has seemed like it has lost power and gained more vibrations so I did a diagnostic and got a p0154 sensor open/not responding/high i know its for an 02 sensor but is there any way to tell which one? Also the bike has v&h BSS does any one know if they take a stock size 02 sensor?
Old Aug 27, 2020 | 07:02 AM
Rapidfire1's Avatar
Rapidfire1
That code should be for the rear sensor. All VH pipes ive run into use the stock size as well.
Old Aug 27, 2020 | 07:18 AM
GreginWV's Avatar
GreginWV
I looked in my Clymer manual for 08-09 it says rear sensor but for 10-11 it doesn't say which one it just says sensor.
Old Aug 27, 2020 | 12:14 PM
nevil's Avatar
nevil
It is for the rear sensor. Before you buy new sensors you should check the wiring and connections for each one. Since the exhaust has been changed out it's possible that something was damaged or pinched in the process.
Here's a guide for the codes, Clymer is not always accurate for every model.
https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Aug 27, 2020 | 03:59 PM
GreginWV's Avatar
GreginWV
Thanks I found it a pin was pulled back in the plug.
Old Aug 28, 2020 | 09:13 PM
Suede Blue Man's Avatar
Suede Blue Man
Originally Posted by nevil
It is for the rear sensor. Before you buy new sensors you should check the wiring and connections for each one. Since the exhaust has been changed out it's possible that something was damaged or pinched in the process....
Good job
FXDWG12
Jun 7, 2013 06:59 AM
viperr817
Jul 20, 2011 10:22 PM
coachchris
Jun 4, 2011 07:15 PM
CQCBlades
Oct 29, 2009 09:21 AM
milfly
Jul 21, 2009 02:58 PM
