Dual Front Disc
Old Oct 22, 2021 | 02:43 PM
eriksweden's Avatar
eriksweden
Originally Posted by Harleywashboy
It will be bolt on. The caliper mount on the slider will look slightly different, but most will never notice. The new calipers are visually different and use different pads, but are functionally the same. There will be no issue with the fender or caliper/disc alignment.
Are the caliper mounts the same , Bolt pattern and location ?
Old Oct 22, 2021 | 02:55 PM
Harleywashboy's Avatar
Harleywashboy
They are located and spaced the same way. The mount looks different depending on year. See post from multihdrdr showing the differences:
https://www.hdforums.com/forum/dyna-...l#post17520998
Old Oct 22, 2021 | 03:02 PM
eriksweden's Avatar
eriksweden
Originally Posted by harleywashboy
they are located and spaced the same way. The mount looks different depending on year. See post from multihdrdr showing the differences:
Old Oct 23, 2021 | 02:08 PM
eriksweden's Avatar
eriksweden
Anything else i should do when i am in the fork ?
As for now i got better springs ,harder than stock pos. Works ok .
Erik
Old Oct 23, 2021 | 07:49 PM
Harleywashboy
Erik
Of course, brand new seals and o-rings. There’s a p/n for a rebuild kit. You could also look at the racetech emulators or the ricor intiminators.
Old Oct 25, 2021 | 09:37 AM
okkomatz's Avatar
okkomatz
I've got a spreadsheet I can send you with P/Ns and costs when I converted my 07 to dual disc and 14+ mags
If you can send that to me I'd appreciate it too! I'll also send you a P/M too.
Old Oct 25, 2021 | 11:51 AM
Harleywashboy
it should be attached to post #8 in this thread. If it isn’t, let me know and I’ll send it tonight.
Old Oct 26, 2021 | 08:59 AM
z06elmo's Avatar
z06elmo
to the OP: I have the OEM low rider S front calipers/pads (Both) front brake master cylinder with the reservoir lever and all that if you're interested. Take offs from my bike.
Old Nov 2, 2021 | 01:18 AM
rogersachs's Avatar
rogersachs
Originally Posted by snake_eyes
So I've been searching and reading about converting to a dual-disc setup on my '17 FXDB. Lots of info on this forum (that's part of the problem) but I still can't find a direct answer to what parts I need for my specific application.
Can I order the right fork leg (disc, caliper, etc.), master cylinder, and brake lines for a '17 FXDLS and convert my bike?
Once you complete, you will love it. How Harley gets away with a single rotor beats me.
Old Nov 2, 2021 | 07:50 AM
snake_eyes's Avatar
snake_eyes
Hey man thanks for the offer, I already had them delivered and sitting in my garage.
