Ignition issue
Old Nov 8, 2020 | 04:21 PM
Courtguy's Avatar
Courtguy
Stage III
Default Ignition issue
2009 FXDC 50,000 miles
A little history first. My stator went bad so I replaced it, I did not replace the battery or voltage regulator. While on a trip my battery got extremely hot swelled very big and was smoking. The main fuse and the battery fuse also blew at this time. I replaced the battery and voltage regulator plus the blown fuses. Now, when I turn on the ignition the N light comes on, the oil light and head light comes on. No other indication lights that come on normally are lit, plus the fuel filter doesn’t hum. The engine cranks but, no ignition all at all. Any ideas on what the problem could be?
Old Nov 8, 2020 | 05:21 PM
Courtguy's Avatar
Courtguy
Stage III
I need to add, this bike is 100% stock with the exception of the compensator sprocket.
Old Nov 8, 2020 | 08:32 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Start with the basics. Check all of the fuses, since the ignition and fuel pump has it's own fuse. Then run a diagnostic scan for errors.
Old Nov 9, 2020 | 07:20 AM
John CC's Avatar
John CC
Blown fuses combined with a hot, smokin', swollen battery indicates the voltage went sky high. Just about anything electrical from the indicator bulbs to the ECM could be fried. Keep digging....
Old Nov 9, 2020 | 01:20 PM
Courtguy's Avatar
Courtguy
Stage III
All fuses are good. How do you bench check the ECM?
jordandavis86
Dec 23, 2018 08:14 PM
bjc
May 22, 2017 07:36 PM
goldie
Aug 22, 2014 11:18 AM
Astro
Oct 22, 2010 05:49 AM
nolanb
Oct 6, 2005 09:35 PM
