Baz
Old May 22, 2017 | 01:24 PM
bjc's Avatar
bjc
Stage II
Default Baz
fitted brand new battery after old one died, when i turn on ignition battery goes down to 7.5 volts and if i try to start engine voltage drops to 1.5 volts, battery is fully charged.
Old May 22, 2017 | 07:36 PM
rkoivisto's Avatar
rkoivisto
You got a pretty bad short. Is the voltage over 12V before you turn on the ignition?
If so, it's time to break out an ohm meter and track it down.
You might try to pull out all of the fuses and put them back in one at a time with the ignition on and watch the voltage.
Eric Robb
May 12, 2019 05:50 PM
bjc
May 23, 2017 02:28 PM
Prot
EVO
24
Nov 16, 2015 02:12 PM
nycgroov
Nov 20, 2005 07:33 PM
nolanb
Oct 6, 2005 09:35 PM
