2007 fxdb
Old Nov 10, 2020 | 08:48 PM
Jshopes's Avatar
Jshopes
Default 2007 fxdb
Im going to look at an 07 street bob when i get off work in a week. Its pretty well bone stock except for a set of saddlebags and a windscreen.
as far as harleys, ive had a 95" 01 road king that ate the tensioners by 30k and had some issues from the magnetti marelli efi, and ive got a 14 limited with a stage 4 103 that, aside from running a little hot, has been rock solid for the last 2 years. I also had a short dealing with an 83 fxr shovelhead that i just got tired of messing with. I wrenched more than rode.
My reason for posting, are there any quirks with the 07 bikes? I read some about compensators, which, isnt a huge deal to me. Ill swap it out when its time. I know its got the 96", the hydraulic tensioners, and delphi efi, both solid upgrades over the tc95 i had. Its bone stock, not even slip ons, although i doubt itll stay that way long. Probably do exhaust, a/c, tune, but i have no idea how itll pull compared to the other bikes since theyre way heavier, so cams may not be necessary.
Old Nov 11, 2020 | 08:29 AM
FxdbCj's Avatar
FxdbCj
Hey man,
I own a 07 FXDB and honestly there isn't too much to worry about. Normal maintenance and it should be one of your more reliable bikes you've owned. Only real issue i have ever had was the rocker support plate snapping which wasn't too big of a deal (other buddy with a tc96 had a similar issue). One annoying thing is 06/07 had a 1 inch axles so not all wheels are directly compatible without a kit. Also connectors from the bars are pretty large and its a bit more of a process if you wanna run the wiring through the bars. But really 10/10 would recommend the year/bike. Good luck
Old Nov 11, 2020 | 11:46 AM
nevil's Avatar
nevil
I've had mine since 2008 and needed nothing more than normal wear and tear stuff and maintenance. I've done some upgrades to brakes, suspension and installed a stage 1. I don't abuse it or baby it, and ride it hard when I feel like it. Which is a lot.
Old Nov 11, 2020 | 01:57 PM
Jshopes's Avatar
Jshopes
Originally Posted by FxdbCj
Hey man,
Im going to have to look into the bars thing, i hate looking at how harley does their wires. I had apes on the king and have them on the tk, both wired internally. It just looks better. Not that its an issue, just a preference. Ive never had a bike with spokes either, so well see how that goes.
Thanks for the comments guys.
brad75raiders
Engine Mechanical Topics
Jul 15, 2017 12:22 PM
kerstingm
Apr 19, 2016 06:55 PM
Vasilis
Feb 24, 2016 10:45 PM
Jules
Aug 1, 2012 06:36 PM
07NYBOB
Sep 11, 2006 09:54 AM
