05 wide glide right switch housing
Old Nov 23, 2020 | 12:42 PM
bbqbrisket's Avatar
bbqbrisket
Default 05 wide glide right switch housing
I'm trying to adjust the angle of the front brake lever downward.
I have loosned the screws on the master and screw on the housing.(unlike other housings, there is only 1 on this)
When it's loose, and I angle the assembly downward, about 3/8 inch, the brake light hangs up and either stays on or flickers.
I cannot seem to line up the linkage so that there is nothing hindering it.
When I place it back in the original position it's Ok.
thanks for help
Old Nov 24, 2020 | 04:48 PM
cggorman's Avatar
cggorman
You rotating the switch housing and lever perch/master cylinder by the same amount? The brake switch is part of the switch housing but requires a tab on the brake lever to keep it depressed so the lights stay off. If the lights come on when they shouldn't, the switch may be loose (there is a leaf spring in the housing pocket to keep it from flopping about), plunger broken (fragile plastic nubbin breaks easily), lever not returning all the way (various reasons), etc.
Old Nov 24, 2020 | 06:46 PM
s-glide76's Avatar
s-glide76
Is it an aftermarket housing. I've never seen one with just one screw.
PurpleShark
Oct 17, 2016 04:12 PM
CPLoudRider
Electrical/Lighting/Alarm
Oct 7, 2014 10:09 AM
Kramer
Wheels/Tires
May 22, 2010 12:09 PM
V2Evo96
EVO
Aug 17, 2009 02:08 AM
SmoothRider
Jul 1, 2006 01:56 PM
