02 88 fxdwg
Old Jan 15, 2021 | 05:14 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by Nomadmax
It can be had cheaper then this
SKU : 6529 - Rocker Box Cover Ratcheting Bolt Wrench - Lang Tools
This works also and can be used in conjunction with a torque ratchet (bearing in mind the angle so torque isn't multiplied).
Motion Pro Rocker Box Cover Wrench - 08-0220 Harley Motorcycle Goldwing | Dennis Kirk
Old Jan 15, 2021 | 02:50 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
food for thought. The rocker assy. will have to be pulled to get your pushrods out, why not install the rocker lockers while you are in there.
Old Jan 15, 2021 | 04:52 PM
Shadowjag's Avatar
Shadowjag
During the weeks of research and trying to keep the cost low, I have yet to see mention of these until now. I'll look into it. Thanks.
Old Jan 15, 2021 | 04:53 PM
Shadowjag's Avatar
Shadowjag
Thanks for the info. It is appreciated.
Old Jan 15, 2021 | 09:26 PM
multihdrdr's Avatar
multihdrdr
If you have no preference, I would lean towards the Rockouts HERE instead of Rocker Lockers. Purely because of the Seller
Old Jan 16, 2021 | 10:03 AM
ROCKOUT Rocker Products
Sponsor
Thanks man, customer service really is our #1 priority
John @ Rockout
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jan 16, 2021 | 10:07 AM
Shadowjag's Avatar
Shadowjag
Off Topic. Bolt cap stuck behind starter. Anyone else pull this off? 😵
Old Jan 18, 2021 | 10:44 PM
seniorsuperglideE8
John @ Rockout
Sorry John, you were the ones I was thinking of. I believe in supporting sponsors.
Old Jan 19, 2021 | 07:36 AM
Campy Roadie
No need to remove the starter for the job you're doing.
Old Jan 19, 2021 | 07:44 AM
Shadowjag's Avatar
Shadowjag
I know that. A rocker cover bolt cap fell between the starter and the motor. Tried a magnet, small screwdriver. Dang thing won't come out.
