Still need help?
Old Jul 31, 2007 | 07:00 AM
grueter's Avatar
grueter
Default Still need help?
Sorry for taking so long to get back. My A.F. # is right at 13. But after several long rides this weakend I get a lot of loud backfire noise only on decell along with some pop,pop popping. Is this OK? Should I call the guy that did the tune or should I call Power Commander and talk to them?The bike runs good and looks even better. Thank you guys are the best. 2006 Wide Glide Vance & Hines (Big Radius) Power Commander III and Arlen Ness AC(Big Sucker) Max Power = 68.01 Max Torque = 74.02 Thanks Again
Old Jul 31, 2007 | 07:12 AM
glide05's Avatar
glide05
Default RE: Still need help?
The PCIII canned maps do not add any fuel at 0% throttle position.
If your tuner started with a canned map, and didn't add fuel at 0% throttle, you will likely have the popping you are experiencing.
You can get rid of most popping by adding somewhere around 10-20 to the 0% throttle settings.
Your bike will idle a bit higher.
Smittyjf
May 2, 2014 04:30 PM
JRichey001
General Topics/Tech Tips
Mar 3, 2014 06:47 PM
cornishman
Feb 16, 2008 02:19 PM
bob53
Sep 21, 2006 11:51 PM
srigas
11
Aug 12, 2006 02:46 PM
