Cam change
Old Jul 29, 2007 | 06:44 PM
damadman's Avatar
damadman
Default Cam change
Hi Im getting ready to do a cam change on my 07 Bob.... Thinkin of just going with the andrews 37's not going gear drive yet..can i get some tips?.. What special tools am i gonna need to do the job right? any thing else i should do while im in there? I got me a manual and im ready to go just want a little assurance thanks.
Old Jul 29, 2007 | 06:53 PM
moosh's Avatar
moosh
Default RE: Cam change
might want to look at this.....
http://www.harleyhog.co.uk/camguidepage1.htm
Old Jul 29, 2007 | 09:15 PM
damadman's Avatar
damadman
I read conflicting things..... some say change the bearings others say the factory one is fine.. now if i change it i need to go buy them 2 expensive tools. if i dont then i may be able to get buy without buying any extra tools. To change the bearings or not??
Old Jul 29, 2007 | 11:55 PM
mentor70's Avatar
mentor70
You will probably love the 37's.
you will need to get two of the old EVO lifter block aligment screws to align the cam plate to the oil pump.
I just used needle nose pliers and an alan key to hold the tensioners.
I have seen the newer bearings and they are different than the ones on my 05. and I dont think you will need a press either for getting the cams out of the support plate, I think they just slide out.
the inner bearings are bigger too, and if you have low miles on it just put the cams in and let her rip!
Old Jul 30, 2007 | 01:22 AM
DyNaMc's Avatar
DyNaMc
Great information let us know how they work out
Old Jul 30, 2007 | 03:05 AM
xxxflhrci's Avatar
xxxflhrci
The info on HH's site is for the old spring loaded tensioner set up. It will not apply for a '07 bike with the newer hydraulic tensioners.
Old Jul 30, 2007 | 05:28 AM
damadman's Avatar
damadman
yeh i seen that, anyone got a right up for the new 07's ??
Old Jul 30, 2007 | 08:42 AM
ride99fxd's Avatar
ride99fxd
You mention "not going gear drive yet." If that means that you may be going gear drive in the future, I hope you are aware that you will have to buy new cams when you do. Chain drive cams and gear drive cams are not the same.
Old Jul 30, 2007 | 10:40 AM
damadman's Avatar
damadman
I do realize that i just want a little somethin for now.... going with GMR's 2200 dollar goodie bag down the road, hopefully.
Old Jul 30, 2007 | 11:56 AM
ride99fxd's Avatar
ride99fxd
With the '06 Dynas and all '07's, they used a redesigned roller chain drive with hydraulic tensioner. It appears to be a much better setup than the older silent chain drive with the mechanical tensioners. The 37 is a nice all-around cam, comparable to the S&S 510 grind.
