Speedometer mounting problem
Old Apr 18, 2021 | 01:15 PM
rasmukri's Avatar
rasmukri
Originally Posted by John CC
You need another angled shim, reversed, on top so the nut sits flat.
(What Mud said....)
Adding a second angled shim on there only moved the misaligned part to the top of the bolt. Both shims are the same size and angle.
It looks loose because I don't have a long enough bolt and the hardware store is a 2 hr drive. I hold it up there tight on the bike and it is off. I hold it just in my hands and it's off, the angled shim idea doesn't seem to work.
Old Apr 18, 2021 | 03:30 PM
R_Einan's Avatar
R_Einan
According to the speed kings instructions, you have to open up the hole in the gauge bracket.
Old Apr 18, 2021 | 08:18 PM
John CC's Avatar
John CC
That may be it. The bolt needs room to pass through the bracket at the same angle. However, eyeballing your photo, it doesn't look like the angles are the same. Look at the drawings by Mud and me. It will work.
Mchad
May 13, 2020 02:10 PM
Bedore
Mar 18, 2019 09:00 AM
imboden
Aug 9, 2013 05:26 AM
PistonPuller
Sportster Parts
Jun 6, 2013 10:15 AM
mr_natural78
Jan 12, 2013 07:03 PM
