New external breather setup
Old Jan 28, 2021 | 04:54 AM
NO4NJNK's Avatar
NO4NJNK
I just ordered this. No chance of dripping from the filter. Now, ill be able to just unscrew the bottom half and pour it out.
They also have this in black.
Old Jan 28, 2021 | 06:37 AM
Steve Sportster's Avatar
Steve Sportster
I just put a DK Custom Products catch can on mine. Joined the two lines from the head breathers inside the 114 air cleaner into a single line. Ran the single line down just below the motor to the catch can. Didn't want to drip oil on the road. Tired of oil in the air cleaner/filter and don't want hot air, oil and water added to cool air in throttle body. We'll see how it does this Spring.
Old Jan 28, 2021 | 08:07 AM
Suede Blue Man's Avatar
Suede Blue Man
Good find, you convinced me, just ordered one myself, thanks
Old Jan 28, 2021 | 08:41 AM
Qdog002's Avatar
Qdog002
Originally Posted by Bob_fxdb
I just use a brake reservoir. Don’t like the filter
How did you vent the brake reservoir?
Old Jan 28, 2021 | 08:43 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don’t be that guy, don’t get that stuff on the road.
I`d rather ride on it than breathe it...
Old Jan 28, 2021 | 08:57 AM
John CC's Avatar
John CC
Just don't lube the rear tire with it!
Old Jan 28, 2021 | 10:19 AM
Jay Guild's Avatar
Jay Guild
Thanks for the suggestion on the can. I have been needing one to replace the breather filter I have on mine that ends up blowing oil all over my leg and the side of the bike.
Old Jan 28, 2021 | 12:15 PM
hdpearson13's Avatar
hdpearson13
I am going to do 3an brake lines and run both side indivaully 36 inch down and under the exhaust no filter or can. Then use 12-24 set screw on intake ports. Want to do black stainless
Old Jan 28, 2021 | 01:18 PM
Campy Roadie's Avatar
Campy Roadie
You could have done it even cheaper if you would have run a hose to the ground. The umbrellas are one way, no need for a filter.
Old Jan 28, 2021 | 01:26 PM
GearheadMike's Avatar
GearheadMike
The filter gets saturated and drips. Why not put the hose and filter to the top, so any residual oil drains down the hose back into the motor?
Have done it before and its better. Now I use a catch can, better yet.
