Vibration problem solved! Thanks meatballs!!
Sounds great. Where is the advertisement you speak of?
http://cgi.ebay.com/ebaymotors/V-Thu...spagenameZWD1V
http://www.jpcycles.com/productgroup...rand=velvaride
Front end seemed loose, I could move it about 1/2" back and forth while riding. Dealer said it was loose andtightened it up. Now that was at 400 miles on bike, kinda sad, bike is new, 2007 FXD.
But still have the decel vibrations at the above speeds mentioned.
My question is, does this procedure help out with the Decel vibrations, as I don't have the other mirror vibrations and stuff? Or is the Decel vibration a normal Harley thing? (This is my first Harley)
I am fairly mechanically inclined, fabrication of parts is my past time, motorwork is a "by the book" thing for me. After reading about dealer techs, I'm starting to wonder if I should let them do my 1000 mile service next week.
As for the "infamous post #30" This came off of another forum so you might want to check that site if you want to read the whole thread. Basically this is a way you can support the motor without the use of a jack while you are putting in shims.
Anyway here is post #30
"Way to go, fine accomplishment! Couldn't you get 2 - 3/8" x 3" longer bolts, remove lower OEM bolt, and install one of the longer bolts to hold engine, then remove the top bolt, check to see if your front motor mount pulls away from the frame mount. If it does have a gap, cut and drill shim stock to fit gap, and install in top hole with longer bolt, then swing the shim stock down to fit lower bolt hole, install correct length final assembly bolt with locktite, then install the final assembly top bolt same as bottom bolt, and torque to specs. As long as you have one bolt holding the engine you wouldn't need another body, or jack...!??Correct?
We use to do stuff like this as a time saver (like swapping bolts one at a time) so you didn't have to support the component."
I've got to be honest here. I'm nota young guy, have bought many new vehicles, both bikes and cages, and always made modifications to brand new vehicles, no big deal. But never, have I had to make so many repairs to a new vehicle, while the dealer tells me it's normal (problems and vibrations),and we all know it's not!
Luckily for me, I enjoy tinkering and making parts and modifications, but what about the guy (or gal) who wants to just buy and ride?
While this project is one of many, and I thank everyone for the info, I will be doing this on the next rainy day, probably before starting another "ACME" project, and finishing the ones on the shop tables.
Don't worry, I'll catch that Road Runner yet....
...Thanks for re-posting that bro, it's a good tip.
