FXDWG lowering
Old Mar 13, 2021 | 10:29 AM
Jon Patterson's Avatar
Jon Patterson
5th Gear
Default FXDWG lowering
Hi Folks,
I have searched online and I am having a difficult time finding an accurate source of information
I am looking to lower my 2004 FXDWG in the back and would like to know what the best options are that will not create clearance issues. As an example the response I got from progressive was that I would need to make modifications to the fender if I installed the 412 11” rear shocks.
Any insight would be great!
Thanks in advance
Jon
Old Mar 13, 2021 | 11:31 AM
HarleyBob52's Avatar
HarleyBob52
I put, what I believe are 10",, Burly Slammers on my 03 every now and then.. No issues with the fender on it....
Old Mar 14, 2021 | 04:47 PM
2011WideGlide's Avatar
2011WideGlide
Don't know if yours is raked the same as my 2011 but even with the preload set down on the rear shocks the low speed handling is a bit off.. It feels like the front end wants to fall over at low speed.
Old Mar 29, 2021 | 07:13 PM
Jon Patterson
5th Gear
Any issue with the belt guard hitting the fender?
Old Mar 30, 2021 | 06:22 AM
Architect's Avatar
Architect
Put your bike on a jack/lift. Unbolt the lower shock mounts and rotate them out of your way. Then with a floor jack, raise the wheel up into the fender. Clearance issue, if they exist will be self evident. Good luck.
Old Mar 30, 2021 | 08:51 AM
Jon Patterson
5th Gear
Thanks
JC1966
Feb 17, 2017 08:17 AM
MartinSporti
2014-2024 Touring Models
Jul 19, 2014 12:02 PM
WideGlideFever
Sep 26, 2013 02:52 AM
Chunker
Nov 8, 2012 07:12 AM
Billie
Mar 4, 2009 08:40 AM
