Need Fluid level help
Old Aug 2, 2007 | 02:23 PM
NISKA80's Avatar
NISKA80
Stage III
Default Need Fluid level help
Just recently bought a used2006 dyna street bob fxbi no service maunal provided. Does anyboby know the correct amount of, primary oil, transmission oil, engine oil, and fork fluid to put back in my bike ? Thanks for any help !!!!!
Old Aug 2, 2007 | 02:27 PM
voyager1's Avatar
voyager1
Default RE: Need Fluid level help
https://www.hdforums.com/m_1385462/m...tm.htm#1385462
this thread tells the story.
Old Aug 2, 2007 | 02:29 PM
voyager1's Avatar
voyager1
RE: the real truth fluid amounts on 2006 bob ????? - 3/15/2007 6:46:09 PM
showPicture("3/15/2007 6:46:09 PM",0,0,0,1385462,263)
Shovelhead Bob
titleAndStar(1610,0,72,false,"HDF Tech Moderator",")
HDF Tech Moderator
[align=center][/align]
Status: offline
06 Dynas have VERY Specific capacities.....
The Trans is 32 oz... PERIOD!!!!!!!!!!!
The Primary is 32 oz..... PERIOD!!!!!!!
Anyone that gives you info other than those capacities is mistaken, and probably has an 05 or earlier version....
They are not the same.... 06 has the COMPLETELY NEW DRIVELINE (Primary and Transmission)......
Old Aug 2, 2007 | 02:31 PM
voyager1's Avatar
voyager1
oil can be a trick,i start with 2.5 quarts,then check,may take a tidbit more than 2.5 .hope that info helps. that is with filter change which should always be done IMO .
meancana
Dec 14, 2015 12:16 PM
Scott Ballz
May 11, 2015 03:58 AM
deeblues
Jul 3, 2007 07:30 AM
Rocket350
May 24, 2007 12:52 AM
voyager1
Mar 15, 2007 10:15 PM
