2009 super glide
Old Apr 18, 2021 | 04:30 PM
TBL2021's Avatar
TBL2021
Default 2009 super glide
I have a 2009 96in with a thunderheader and a cobra air cleaner , FP3 , its running rough at idle but smooths out at higher rpms , ran it yesterday and was running down the highway and temp got up to 270 so I headed home had a code that the rear cylinder was lean . Both o2 sensors are new .
seems that I have a leaking injector I sprayed carb cleaner at the base of the rear injector and it stalls .
Left plug is front cyc right is rear
And they have maybe 150miles on them
Old Apr 28, 2021 | 09:49 PM
BUILT's Avatar
BUILT
If it's leaking air at the injector or manifold you will have a lean condition and excess heat. Unmetered airflow will destroy your engine and needs to be fixed. I'm not really sure what your question is though?
Acelaw
Oct 29, 2013 06:43 AM
KnotBlue
Oct 14, 2013 03:48 PM
SA315B
May 23, 2010 03:47 PM
MINI SSS
May 2, 2010 11:52 AM
2008FLHP
Dec 8, 2008 06:07 PM
