ABS buzz sound?
Old May 14, 2021 | 12:37 PM
Pianoman18's Avatar
Pianoman18
Default ABS buzz sound?
Ever since I got my 17 Wide Glide last summer, when braking there is an audible buzz sound, about as loud as a beard trimmer. I've just chalked it up to the speed sensor doing its thing.
But yesterday, I rode all over town: to work, to meet my girl for lunch, to the dealer, and took a scenic route home. I realized that the noise has stopped now. There is no more buzz when touching either brakes. I did ride aggressively and had to brake hard at a couple yellow lights but otherwise it was normal bobbing.
Which scenario is normal? Buzz or no buzz? Anything to check? Is this the ABS or something else? Thanks in advance.
Old May 14, 2021 | 07:27 PM
Pianoman18's Avatar
Pianoman18
Seriously? Nobody has ABS on a Dyna?
Old May 14, 2021 | 07:44 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Some times when new brake pads or in your case a new bike with new pads will make buzzing sound when brakes are applied. This is the sharp edge on new pads wearing against the rotor vents and the noise will slowly diminish as the brakes are being "broke in". When I replace pads I usually file the edge "leading to the Rotor" down to a bevel and no noise. Hope this helps.
Old May 14, 2021 | 11:02 PM
Pianoman18's Avatar
Pianoman18
Huh, maybe. I got the bike used and I'm pretty sure they didn't put new pads on at only 3500 miles. It definitely sounded like an electronic buzz. I'll keep an eye on it I guess.
Old May 15, 2021 | 05:37 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Do you know what brand of pads are on it? I run EBC pads and they have a distinct "buzz" noise for the first couple hundred miles or so after installing them.
Old May 15, 2021 | 09:02 AM
Crazy's Avatar
Crazy
That, and I've found that some floating rotors make a buzzing sound when relatively new. Both my Street Bob and Super Glide did that until they had 10,000 miles or so.
Old May 15, 2021 | 11:07 AM
Pianoman18's Avatar
Pianoman18
Huh, weird. Thanks, guys! Makes sense what you're saying. It sounded so "electronic" and consistent I was sure it was the ABS module or speed sensor. My 48 never did it though and it doesn't have ABS.
scooty2321
Oct 1, 2019 06:38 PM
haithum_awni
Sep 30, 2017 02:55 AM
JBCK727
Feb 22, 2016 10:01 AM
osudvm
Feb 14, 2014 11:07 PM
sd1209
Apr 18, 2010 04:35 AM
