External breather
Old May 18, 2021 | 06:47 PM
Shadowjag's Avatar
Shadowjag
Default External breather
Installing one due to blowby. Call me ignorant but how would you plug the old inlets?
Old May 18, 2021 | 08:08 PM
misfitJason's Avatar
misfitJason
Not plug. Cover. With a vacuum cap
Old May 18, 2021 | 08:31 PM
Shadowjag's Avatar
Shadowjag
Vibration won't shake it loose? Glue? Thanks.
Old May 18, 2021 | 09:49 PM
TOE_CUTTER's Avatar
TOE_CUTTER
If you're worried about it, put a hose clamp on it.
BTW, if you are having excessive blow-by, it's time for a rebuilt, not a band-aid.
Dave
Old May 19, 2021 | 06:27 AM
misfitJason
Use a vacuum cap and zip tie it on
Old May 19, 2021 | 06:46 AM
Shadowjag's Avatar
Shadowjag
Thanks. Blow by happened after replacing the cam tensioners, inner bearings and rocker breathers. Recent. The band aid is for a scheduled trip. Drilling out the breathers when return.
Old May 19, 2021 | 11:40 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you are installing external breathers from the head vents, Google videos for external breather systems on Harley Davidsons. I don't know why you are showing a picture of the carb, the hose with the clamp is the fuel inlet to the float bowl. Good luck.
Grove Rat
11
May 6, 2019 01:32 PM
bleezy183
Dyna Parts
Sep 5, 2018 12:10 PM
smokey-the-bear
Jan 5, 2014 03:47 AM
NewfieRocker
May 4, 2010 01:36 PM
dawg
Nov 3, 2008 11:26 PM
