2K Lowrider constantly dies
Old May 25, 2021 | 04:39 PM
Peter Byrne's Avatar
Peter Byrne
5th Gear
Angry 2K Lowrider constantly dies
I have a 2000 Lowrider that randomly dies after riding about a mile or two. At first, it acted like the battery just went dead after riding half of the day, but would restart with a jump. So I made sure my battery stays charged, terminals are tight and replaced the regulator after checking it and finding a hole in the back side of it. Took it for a ride and made it a few miles down the road and it just quits on me again. So I replaced the stator too just to make sure it wasn't a charging issue. I checked for codes and I get a BAS historical fault. Got a new sensor off Ebay since Harley doesnt really source them anymore, and threw it on there today. Fired up the bike and it dies again... so I get a new battery thinking I just wore that one completely out. I got it down the rode about a mile again today and bam! Dies once again.... No warnings, no weird sounds, just shuts off. I try cycling the ignition, shutting it off completely and even letting it cool off for a while and its not kicking over. I checked all of the sensors and cleaned them. Fuzes all seem fine. No burnt or disconnected wires anywhere. I pulled my starter switch on the bars and checked those (added dielectric grease too) and traced all my grounds, all seem fine. No other fault besides the historical BAS (44) code.
The only things left I can think of are the Cam and Crank sensors?
I've been chasing this ghost for a month now and I'm at a loss.
Old May 25, 2021 | 05:37 PM
union53's Avatar
union53
Does it just die or does it sound like it's looking for gas before it dies? On the surface sounds like the carb needs to be looked it. I would check for slow fuel flow. You let it sit and the bowl fills with fuel. You start it and ride it the bowl empties out since the fuel flow can't keep up and the bike dies. Just a thought.
Old May 25, 2021 | 05:58 PM
Peter Byrne
5th Gear
No sir, it just quits. I thought it may have been a fuel issue too... and along with everything else I replaced, I also installed a new petcock (Pingel) and all of the fuel lines. I made sure the tank was emptied and rinsed. Carb is a Mikuni the PO installed along with a 96" kit. Ive never had a problem with it in a couple thousand miles since I bought it. 27K miles.
Old May 25, 2021 | 07:35 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Try riding with the gas cap off, if the the vent in the cap is plugged, the fuel won't flow properly to the carb. When the bike dies, take the float bowl off and check for fuel in the bowl. Once you get the fuel delivery system checked out, then work on the components controlling ignition.
Old May 26, 2021 | 08:25 AM
2011WideGlide's Avatar
2011WideGlide
That was my first thought too as I had a Bonnieville that did the same thing and it turned out to be the vent in the gas cap was stuck. But the OP sounds like an electric issue. I'm thinking a ground issue. You said you checked the battery terminals but did you check the ground?
Old May 26, 2021 | 09:23 AM
MRFREEZE57's Avatar
MRFREEZE57
if it is a carburetor equipped model that sounds like loss of ignition. if it were fuel starvation it would not die suddenly with a carb.
Old May 26, 2021 | 10:57 AM
Peter Byrne
5th Gear
I checked the bike again yesterday after it cut off. I pulled the plug and checked for spark against the rear cyl, I got nothing. I can go out now and it'll start up fine, but will die again after a few minutes or a mile down the road.
I'll have to pull the wires around the ignitions and check I suppose. Maddening! Lol
Old May 26, 2021 | 11:50 AM
2011WideGlide
I once had a Chevy pickup which would do similar. Finally chased it down to a grommet in the firewall not properly installed that let the insulation on a wire get rubbed off and it would short out the ignition when it got warm. Maybe start checking the ignition wires or maybe a wire that is losing connection in one of the wiring harness plugs?
Maddening for sure. Just make sure you only ride it uphill. LOL
Old May 26, 2021 | 11:57 AM
Peter Byrne
5th Gear
Lol. Will do! Thanks
Old May 27, 2021 | 05:56 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I had a similar issue with an 02 Super Glide. Took me about a month to figure it out. Turns out the battery cable had broken inside the insulation. As long as the bike was idling or riding slow it was ok, as soon as I started riding more than 5 or 10 MPH the vibration of the motor or bumps in the road would cause the cable inside the insulation to lose contact and shut off. I put new battery cables on and it never happened again.
