Banjo size on ‘09 FXDC
Old Jun 15, 2021 | 04:01 AM
TeeJayEe's Avatar
TeeJayEe
Default Banjo size on ‘09 FXDC
In the process of changing lines on my 09 FXDC at the weekend I noticed the brake line included in the Burly cable kit I have has a different sized banjo fitting to stock at the m/c.
Shown in the pic versus stock bolts.
If I’m going to get a new line made up, what size banjo fittings/bolts are at the upper and lower ends on the 09?
Thanks
Old Jun 15, 2021 | 10:01 AM
Reindeer's Avatar
Reindeer
Master cylinder fitting should be 7/16" and caliper is 3/8".
Old Jun 15, 2021 | 10:18 AM
TeeJayEe's Avatar
TeeJayEe
Great, thanks.
The bolts included with the kit are indeed those sizes, but the banjo is a smaller outside diameter than stock (hole diameter is the same). Is that an issue?
Old Jun 15, 2021 | 10:19 AM
Reindeer's Avatar
Reindeer
Originally Posted by TeeJayEe
Great, thanks.
I can't see why the outer diameter would make a difference. I didn't catch that's what you were referring to.
Old Jun 15, 2021 | 10:44 AM
TeeJayEe's Avatar
TeeJayEe
Sorry yes you answered my main question about the bolt sizes.
I just wondered if the smaller banjo fitting was a problem, it fits, obviously, it’s just the surface area on the m/c where the washers/fitting mount up to is slightly larger. I’m possibly being paranoid, if it was any other part than front brakes I’d have given it a go already!
Fozzy4325
Wheels/Tires
Feb 2, 2014 12:07 PM
Dannell53
Mar 6, 2012 03:47 PM
Jroymcd
May 25, 2010 08:46 PM
donutsrd
May 20, 2009 09:40 AM
honestbob
"The Florida Crew"
May 10, 2009 11:46 AM
