2003dyna
Old Jun 15, 2021 | 11:39 AM
Quiet&storm's Avatar
Quiet&storm
Stage IV
Default 2003dyna
I have a 2003 Dyna the tachometer will not work any suggestions
Old Jun 15, 2021 | 12:14 PM
nevil's Avatar
nevil
Check your fuses and wiring.
Old Jun 15, 2021 | 05:44 PM
Quiet&storm
Stage IV
I checked that stuff all looks good all fuses are good no cheese in/on connectors I haven’t found nothing out of place so far I’m a little stumped
Old Jun 16, 2021 | 12:13 AM
fxdx1985's Avatar
fxdx1985
Check the speed sensor. My 2002 did it once, I unscrewed the speed sensor and wiped some gunk off of it the tach worked fine after.
Old Jun 17, 2021 | 04:56 AM
Quiet&storm
Stage IV
Speed sensor has been cleaned and I checked the wire coming out of it going up under the seat all looks good
Old Jun 17, 2021 | 01:56 PM
eighteight's Avatar
eighteight
Does the light in the tach work ? ( the power wire)
Needle doesn`t move ? ( the signal wire)
Old Jun 18, 2021 | 07:09 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Are you sure all connections are seated properly?
Check out the wiring diagrams at Harley SIP......
Old Jun 18, 2021 | 08:58 AM
eighteight's Avatar
eighteight
^ FXD , I salute your service to your nation
Old Jun 18, 2021 | 09:01 AM
Iceman24's Avatar
Iceman24
Maybe...it just sh@t the bed and needs to be replaced??? Time for an upgrade...
Old Jun 24, 2021 | 10:37 AM
Quiet&storm
Stage IV
yes it lights up only
