Best performance plugs
Old Aug 6, 2007 | 08:56 AM
wisemx's Avatar
wisemx
Default Best performance plugs
...Let's kick this in the pants one more time.
What have been your best Spark-plugs on Dyna's with carbs?
For me the best, so far, have been the 6R12G Gold plugs Harley sells through the SE line.
Old Aug 6, 2007 | 09:08 AM
dlstanf2's Avatar
dlstanf2
Default RE: Best performance plugs
That's what I am using. What about plug wires?? I'm looking for some Accel type yellow plug wires for the 06 Dyna. Seems that the fuel injection units are pretty finicky about plug wires.
Old Aug 6, 2007 | 09:18 AM
wisemx's Avatar
wisemx
Thanks.
All of my electrical is custom, the wires that have worked best are RevTech, hands down.
I was also able to get them in black so they match the wrinkle black engine.
I like my bike to look likea sleeper, the colorful wires are cool but sure stick out.
Old Aug 6, 2007 | 03:22 PM
Rebel Ryder's Avatar
Rebel Ryder
ORIGINAL: wisemx
I think my used fxdwg came w/those... are they split fire type I recall my se's were?
I replaced w/accell's -didn't think the price of se's were justified, now I wonder???
wisemx - what's the main reason for your choices? are you endorsing the combination of plugs/wires too? why revtech?
just curious bro, any answers are good - thanks in advance!
Old Aug 6, 2007 | 03:59 PM
wisemx's Avatar
wisemx
Good friend of mine owns a large Custom bike shop with a fast paced dyno.
In every test the RevTech wiresdeliver the best spark and amazingly shield the rider,pure genius.
I've tested lots of plugs in this bike, primarily the rear cylinder shows the most change with some of them.
The 6R12G Gold plugs were a test, not sure who makes them for Harley but they rock.
Old Nov 27, 2007 | 03:22 AM
Rebel78's Avatar
Rebel78
wisemx; did u try Screaming Eagle Triple Platinum Performance plugs or HD Double Platinum spark plugs? I'm planing to change my plugs & wires with HD or SE, but I'm so confused! I use 98 octane by the way.
Old Nov 27, 2007 | 08:28 AM
flynavy's Avatar
flynavy
Rebel,
Don't be confused, bro. Just learn everything you can and seperate fact from opinion. Bottom line is: use what works best with your bike for your riding style/habits. Plugs and/or wires do nothing for performance, although my bike does seem to idle steadier and start easier with the SE Perf (splitfires). If they didn't, I'd take them out.
Trial and error. The only thing to be sure of is if you change exhaust and breather to higher flow, you should do something to compensate for a better fuel mixture. The ECU can't handle it alone, and the Stage I default dl is worthless - that's a fact.
There are many ways to go for fuel management, and it just all depends on how far you intend to go with your bike to determine what you get. Read all the posts on PCIII, Fuelpak, SERT, Thundermax, etc. andyou will get a lot of opinion and dissimilar comparisons. It WILL make your head swim.
If you have a local dealer you trust, call them and speak to their chief tuner tech. Tell them what you want; high performance and don't care about sound or fuel economy, just want the bike to run it's best hp and torque be damned, or a bit of power, good sound, decent fuel economy. Yes, you CAN have it all. They "usually" give it to you straight. If they say, "you have to get this or else..." hang up. Do a google on Latus HD. They have an on-line tech ask forum that is good. The guy has serviced HD's and Indians for over 20 years. He will give it to ya straight.
Just do what works and ride....
Back-n-Black
General Topics/Tech Tips
Sep 26, 2016 11:40 AM
hd4evr2008
Apr 2, 2016 10:53 PM
falsealarm
Aug 15, 2010 10:34 PM
scorchedearthpolicy
Jul 6, 2010 08:34 PM
07yellowglide
Feb 25, 2008 05:37 PM
