Hooking up battery
Old Aug 10, 2021 | 04:18 PM
sharps45100's Avatar
sharps45100
Default Hooking up battery
Putting a new battery in a 2005 dyna low rider, fuel injection. There is the normal positive and negative cables. There is also what looks like a 16 gauge black wire and don’t know if it goes on positive or negative terminal. Anyone have a clue where it goes? Friends bike and its been in storage for 6 years with no battery so any help be appreciated!!
Old Aug 10, 2021 | 04:38 PM
im's Avatar
im
By chance is it for a battery tender ?
You will need to follow were it goes.
Old Aug 10, 2021 | 04:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
There would be no extra wires at the battery post on a stock configured bike.
As im said, you will have to trace it back to where ever it goes and figure out what was added.
Don`t forget to connect the positive cable first, then the negative.
Old Aug 10, 2021 | 05:40 PM
sharps45100
Bike has a key fob so could it be for an alarm?
Old Aug 10, 2021 | 05:53 PM
MURPHCC1's Avatar
MURPHCC1
follow it back and find out........
Old Aug 10, 2021 | 09:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
We can only guess, and that does you no good....
You must trace the wire and see where it goes.
Old Aug 13, 2021 | 12:05 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
First , there may be a short 8 ga. going to a bolt to the frame. Wiggle the 8 ga. cable from the starter copper post , that will be a positive to the battery. For the life of me, I don't know why HD didn't put some sort of red leads on the positive cable. Connect positive first then the negative. You may want to put an overnight charge on the battery first using a smart charger.
Old Aug 15, 2021 | 07:02 AM
sharps45100
I figured out the small wire, it is the ground for auxiliary lights that his dad put on when he owned the bike.
Old Aug 15, 2021 | 07:19 AM
Iceman24's Avatar
Iceman24
Great job...sometimes tracing wiring on these rides can be a beoutch! Glad you found the connection/use...ride-on!
Old Aug 15, 2021 | 07:22 AM
Hoginedgewood's Avatar
Hoginedgewood
Funny thing is I was going to guess his dad had an extra ground wire ran for the lights.
bill from tn
Jan 22, 2023 04:22 PM
painey
Milwaukee Eight (M8)
Dec 14, 2018 12:47 AM
rockon
Nov 3, 2017 05:56 AM
dpoll995
Feb 10, 2017 03:24 AM
pt4u2nv
Jan 20, 2017 08:36 AM
