Stupid Question
Old Aug 7, 2007 | 11:32 AM
Rebel Ryder's Avatar
Rebel Ryder
Default RE: Stupid Question
now I have a stupid question: does the manual your using have any pictures?
BTW I stripped one of my torx heads so the derby cover never comes off and I just use the inspection cover (4 hex bolts)for fluids.
Old Aug 7, 2007 | 12:32 PM
dlstanf2's Avatar
dlstanf2
Rebel Ryder, did you strip the bolt or the socket head? Your local NAPA dealer or Sears can provide you with a set of Extractors that will remove the cover bolt. If you stripped the cover bolt threads, you might need to drill and re-tap the threads. Not such a bad thing to do. Take your time.
Old Aug 7, 2007 | 01:32 PM
Rebel Ryder
ORIGINAL: dlstanf2
stripped the torx head. thanks for the advice/input. one of these day I might try your suggestion, however, I'll probably just end up scratchingsome precious chrome. [:@]
Old Aug 7, 2007 | 01:39 PM
kerberos's Avatar
kerberos
ORIGINAL: lilrooster76
maybe i am just stupid, but i sure dont see that on my 07 FXDC, nor do i see it in the maual
it says this as for filling...."pour 32 oz of primary chaincase lubricant in through the clutch inspection cover opening"
thats a nice round plate with 5 torx screws in it....which I always thought was called a derby cover....which again brings me to the question of is this a derby cover?
and if dont have that rectangular cover how the F&^% do i know if its overfilled or underfilled?
'07s have a self tensioning primary chain. The rectangular cover isn't there.
Old Aug 7, 2007 | 02:03 PM
Dynamite17's Avatar
Dynamite17
well the only reason i ask is that the manual describes what i always thought was the derby cover as the clutch cover...was going to buy a new cover when i changed the fluid
I have an '07 Lowrider and had the same question. The answer is yes. The Derby cover with the 5 torx heads is the inspection cover. I replaced the stock cover with this one which uses a "frisbee"style gasket.
So, if I want to check the level, they reccomend installing a new gasket. Looks like this:
Not a great setup.
Also, I broke my Sears crapola Torx bit trying to get it to 84-108 in-lbs. Get a hardened Snap-On bit before doing this one.
B
Old Aug 7, 2007 | 03:51 PM
lilrooster76's Avatar
lilrooster76
Thanks for the info
sstandefer
Milwaukee Eight (M8)
Jul 6, 2020 03:12 PM
pounder35
Mar 21, 2019 06:24 PM
WVDevil
Jun 21, 2015 10:19 AM
foglies
May 26, 2014 11:01 AM
Dancemax
Sep 24, 2006 09:25 AM
